hd21 craigslist |
michale34
Topic: hd21 craigslistPosted: 16 May 2013 at 11:22am |
craigslist 3803057313 heres a hd 21 price seems steep to me.
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35339 |
Posted: 16 May 2013 at 8:38pm |
Kinda hard to look at it without a site address, the CL number doesn't go anywhere in particular.
michale34
Posted: 17 May 2013 at 9:11am |
sorry craigslist little rock ar
James Coons
Posted: 17 May 2013 at 9:19am |
Here's the link
http://littlerock.craigslist.org/grd/3803057313.html It is very high I think, Missing Radiator, torched track. Maybe they'll come down on the price with some coaxing. If it helps save it I do have a good radiator, hood, and a few other odds and ends that will fit it. |
michale34
Posted: 17 May 2013 at 4:52pm |
I think i heard some talk about this tractor a few years ago .I heard of a hd 21 that had a cutter blade on it that was in a patch of woods in that area that someone had shot holes in the radiator . the machine suposely had trouble with the final drive and was parked I dont know if this is the same machine or not but with the radaitor missing and a track cut it might be . or on the other hand scrappers my have taken the parts but the exhaust is covered and the air cleaner is on so i would think scrappers would just leave it uncovered.I might take a ride and look at it . its only about 80 miles from me.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 17 May 2013 at 10:15pm |
looks like an early model 55-58 Buda/Lanova with HD844 and mechanical blower similar to detroits before the use of turbos
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 18 May 2013 at 12:07am |
What do you think it was used for? Kind of unusual to have a winch and no blade. Can't see $8,500, maybe $3,500.
Allis Express participant |
CAL(KS)
Posted: 18 May 2013 at 6:27am |
could have been used to pull scrapers with dual spool rear cable unit, or more likely blade was removed to tilt nose/remove radiator and sold/scrapped/lost. yes quite high for not running and no blade.
they are hard to load when they don't run. doesn't run = no hydraulic power = no steering even pulling it around with a similar size machine is a challenge. have done this with HD16s Edited by CAL(KS) - 18 May 2013 at 6:30am |
