301 Performance Head Photos |
Page 12> |
| Author | ||
O.P.S. Heads
Thanks(1)
Topic: 301 Performance Head PhotosPosted: 13 May 2013 at 6:59pm |
The second one of these so far. Enjoy the photos. If anyone can help me size them correctly it would be much appreciated.
Edited by O.P.S. Heads - 13 May 2013 at 8:51pm |
| Sponsored Links | ||
DougG
Posted: 13 May 2013 at 7:40pm |
Very nice,, completely home made or just doctored up ?
O.P.S. Heads
Posted: 13 May 2013 at 7:51pm |
It's a new, solid casting not an OEM head with the water jacket filled. This allows for improved intake and exhaust ports.
Mikez
Posted: 13 May 2013 at 7:57pm |
That's sweet looking. Have you put any on a engine how does it perform
O.P.S. Heads
Posted: 13 May 2013 at 8:04pm |
The first head we made ran on a single turbo, big cube engine in the LLSS class. Although we never did any direct dyno comparisons between it and an OEM head, I think it was a nice improvement performance wise. The flow numbers are considerably more than OEM which allows a larger turbo to be used.
Edited by O.P.S. Heads - 13 May 2013 at 8:05pm |
Mikez
Posted: 13 May 2013 at 8:17pm |
Big turbo is always fun lol. Is this your own tractor your running it in. What other engines do you play with
Dnoym N. S. Can.
Posted: 13 May 2013 at 8:21pm |
this is what it look like @ 480 with and 270 height when you up load your picture you can change the size. in Image Propertiesyour size is 1920 with1080 height what ever you do to one number you have too do to the other number or it will look funny HTH B:-) Dnoym Edited by Dnoym N. S. Can. - 13 May 2013 at 8:26pm |
O.P.S. Heads
Posted: 13 May 2013 at 8:25pm |
The big cube single was mine that I sold to a buddy. That's when this type head was used after he bought it. I have another friend with a twin turbo LLSS model 180. Right now he is still using the OEM head. I don't have a tractor of my own anymore. Haven't for years. Still enjoy tractor pulling and in particular the 301 engine. We struggle to keep up with the red and green tractors around here. The improved head is designed to narrow the gap and last longer than the old OEM heads which my buddy replaces every year due to cracks.
O.P.S. Heads
Posted: 13 May 2013 at 8:29pm |
Dnoym,
I like that size a lot better. Where do you find the "image properties" button?? |
DougG
Posted: 13 May 2013 at 8:35pm |
I do like messing with the 301 too,, lots of power/ potential outa a small package ,, and always in a One Eighty too!!
Edited by DougG - 13 May 2013 at 8:36pm |
wi50
Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
Posted: 13 May 2013 at 8:36pm |
Awesome. I'm just curious if the exhaust manifold is on it for some reasons we talked about
O.P.S. Heads
Posted: 13 May 2013 at 8:48pm |
Not on this one(and yes I know what you are talking about). The manifold is there just to illustrate how a stock manifold will fit. The intake side uses the 426 intake manifold bolt pattern so a 426 intercooler will bolt right on if need be.
Dnoym N. S. Can.
Posted: 13 May 2013 at 8:51pm |
in the quick reply message at the bottom of this post you will see the up/side ways arrow hit that button and then click on the picture of the tree that will bring you to the image properties and the image you all readed loaded so if you click on one of your picture you will see on your right where you can see the size so i took and divide them number by 4 B:-) Dnoym Edited by Dnoym N. S. Can. - 13 May 2013 at 8:58pm |
O.P.S. Heads
Posted: 13 May 2013 at 8:54pm |
Thanks a bunch. I'm not all that sharp so I need all the help I can get.
O.P.S. Heads
Posted: 13 May 2013 at 9:01pm |
It's not that you aren't doing a good job of explaining it, but I still am having trouble. I when I get to the tree and click on it, all I am getting is a chance to upload more pics.
cornbinder
Joined: 26 Sep 2011 Location: jeromesville,oh Points: 846 |
Posted: 14 May 2013 at 2:40am |
real nice cyl. head. there is lots of power to be had bye a cyl. head that flows well. can you do that head that the water jackets aren't filled for guys like me that want better performance for guys like me that want to pull and still put their tractor in the field?? or is it strictly for higher rpm pulling?
Dnoym N. S. Can.
Posted: 14 May 2013 at 7:42pm |
you must be useding a hosting site to up load your picture i did fine some more help for you don`t give up your all most there .there people hear that will help you
B:-) Dnpym |
mattb
Posted: 16 May 2013 at 9:52am |
How much bigger is a 426 valve? Im running a naturally aspirated 301 at 2400 rpm in antique farmstock and looking to get more power out of it.
lussetto
Joined: 05 Nov 2010 Location: Bridgeport, NE Points: 63 |
Posted: 16 May 2013 at 1:17pm |
Would like to talk to you about the head set up.
Greg 308-279-0232 |
O.P.S. Heads
Posted: 16 May 2013 at 1:22pm |
Matt B. The 426 intake valve diameter is 1.835". A stock 301 valve is about 1.600 if I remember right. Depending on your bore diameter you can go with a bigger valve which will yield more flow yet. The ports are big enough. Flow bench results show that an OEM head with 426 valves will flow about 160 - 170 CFM on the intakes with a normal port and polish job. This head was at 240 CFM with 426 valves. The very first head was @ 285 CFM with 2.00 inch dia. valves. I am working to improve the port more yet and the goal is to get 265- 270 with the 426 valve.
Greg, Email me - opsheads@hotmail.com Edited by O.P.S. Heads - 16 May 2013 at 1:26pm |
AC200Puller
Joined: 04 Dec 2011 Location: Wisconsin Points: 774 |
Posted: 17 May 2013 at 3:00pm |
Nice looking head. Do the sleaves have to be cut for the 426 valves on this head?
O.P.S. Heads
Posted: 17 May 2013 at 9:18pm |
The valves in this head are located in the same position as an OEM head so if you are less than 4 1/8 dia. bore you will need to notch the sleeves so the valves will have proper clearance if you are using 426 sized valves.
It is not mandatory to use 426 valves. Depending on how the head is machined, smaller valves could be used. Edited by O.P.S. Heads - 17 May 2013 at 9:21pm |
AC200Puller
Posted: 18 May 2013 at 9:24am |
Ok Thanks. Keep up the good work!
bkostishion
Joined: 02 Jun 2015 Location: Nazareth, Pa Points: 1 |
Posted: 02 Jun 2015 at 9:17pm |
do you have any pictures showing how you notched out the sleeves? thanks.
Ken(MI)
Joined: 14 Sep 2009 Location: Lansing, MI Points: 619 |
Posted: 03 Jun 2015 at 7:04am |
Nice looking work!
KevinON
Joined: 07 Dec 2009 Location: Schomberg, ON Points: 810 |
Posted: 07 Jun 2015 at 5:21pm |
Do your heads work with a 301 twin turbo or do you require more cubes? Very nice work btw.
Allis Silver Pony
Posted: 26 Jul 2025 at 1:57pm |
Im building an Allis 301 2900 for my 1 ton pickup. A shop is tuning up a fuel pump and I'll have to modify the timing plate for the pump. Anyhow, I was porting my head and may have messed up the valve seat. The head I see that I believe you built, I'm highly interested in. Are you selling these?
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6117 |
Posted: 26 Jul 2025 at 6:14pm |
That was 12 years ago, and the head was solid- no cooling passages... tractor pulling only, so you wouldn't be running it in a 1-ton pickup for very long...
Allis Silver Pony
Posted: 27 Jul 2025 at 12:10pm |
Yes definitely. I was porting my 301 head and I took too much out below the valve seat. I got excited stumbling across this thread. I'm assuming simply buying another 301 head would be the best bet. I do need more flow though, so I would have to apply my lessons learned here..
BobEvans
Posted: 14 Sep 2025 at 12:50pm |
Hey im interested in one of those heads
Page 12> |
