combine engine |
Karl
Joined: 01 Aug 2010 Location: WI, Marshall Points: 26 |
Topic: combine enginePosted: 09 May 2013 at 9:27pm |
hello everyone. What model of combine did the 301 diesel with the in line simms pump used in. And about what year?
Posted: 09 May 2013 at 9:34pm |
1972 and 1973 model "L".
Karl
Posted: 09 May 2013 at 10:09pm |
ok Thanks for the info
Karl
Posted: 02 Jun 2013 at 10:56am |
How about the M model combine ? did that have a "simms" pump also.
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 29 Jun 2013 at 11:30pm |
dad thinks the 73 M 130 hp version (opposed to the 120 hp standard) may have had the simms.
I dont think the simms made it past 73, but it may have. Dr. Allis is spot on on the L's. we have one 73 L hydro with the simms that actually starts ok, otherwise they dont seem to start as well as the Roosa's
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 30 Jun 2013 at 11:26am |
I have a 3500 MK II industrial engine with a Simms (Minimec) pump and.048 injector tips.
Best I can figure it is the 224 HP setup. Added an intercooler and put it in my 220.
Dynos 190Hp without touching the settings. Starts like a new modern tractor.
GM Guy
Posted: 02 Jul 2013 at 5:31pm |
if anyone is looking for a simms powered 301, we have one that ran when parked, may have a few more, just need to check what the parts combines have in them. one for sure in NW KS.
did the construction equipment use the simms more than the roosa? it seems the farm equipment didnt use the roosa very much.
Posted: 02 Jul 2013 at 6:28pm |
Farm equipment almost exclusively used RoosaMaster pumps! Simms in-line was the odd-ball on Farm equipment and never on an AC tractor and only 1972 and 73 Gleaner combines, maybe a 74 model, but I've never seen one. Out of all the hundreds of Gleaner combines I've worked on since 1975, I can only remember seeing THREE of those orphan 301/Simms engines.
GM Guy
Posted: 02 Jul 2013 at 6:50pm |
Dr. Allis, what all construction equipment used the 301 with simms?we have 2 out here, and 3 or so in idaho of the 301 simms engines in combines.
trying to keep a few of those running though. Edited by GM Guy - 02 Jul 2013 at 6:51pm |
Posted: 02 Jul 2013 at 8:12pm |
Wheel loaders I have seen with 301/Simms.....maybe a 545 or 645 size.
Mactractor
Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
Posted: 02 Jul 2013 at 8:42pm |
Yep, 545 and 605 wheeled loaders.
Lazyts
Posted: 02 Jul 2013 at 10:29pm |
A local contractor has a 605B loader which came with the Simms pump. The engine went on it, so he installed an M engine. Now they call it "the jackrabbit"- the acceleration characteristics are quite different, and it is harder to maintain a constant speed- the roosa master seems to be more sensitive than the inline pump.
