720 drive shaft |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: 720 drive shaftPosted: 25 Apr 2013 at 12:45pm |
My brothers 720 vibrates in the back and he thinks the driveshaft is bent (It does have a wobble to it). He had replaced the flex coupling when he had it apart, so that should be ok. Any other ideas?
Any other way to remove it without moving the engine? Any used ones out there? I had heard at one time that other brands (Other than Powermax) might match up as it was a common shaft |
Charlie
aras
Joined: 28 Jul 2011 Location: Weston, WI Points: 665 |
Posted: 25 Apr 2013 at 2:34pm |
I took mine out and straightened it in a press. I was able to remove it after the cover on the middle section is removed on the topside.
The coupler needs to be checked for runnout when installed on the engine
Charlie175
Posted: 25 Apr 2013 at 2:44pm |
Can you explain what you mean by runout?
Charlie
aras
Posted: 25 Apr 2013 at 3:28pm |
The shaft must be concentric to the engine pulley.... I'll see if I can find the service manual
RichinWis
Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Posted: 25 Apr 2013 at 4:36pm |
Runout is how much wobble the shaft has, in laymans terms if the shaft is bent or tweaked it will wobble
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55341 |
Posted: 25 Apr 2013 at 5:58pm |
Charlie, also check that it was re-assembled correctly. I always mark a shaft, with paint, on each part, and U joint. If the U joints are out of phase, that will vibrate like crazy.
Charlie175
Posted: 26 Apr 2013 at 7:10am |
Thanks for the help!
Charlie
