226 in a CA |
Zyta
Topic: 226 in a CAPosted: 20 Jan 2010 at 10:56am |
Has anyone ever installed a 226 in a CA is it possible with out alot of trouble?
Jim
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 20 Jan 2010 at 11:02am |
It is not just a bolt on if that is what your asking. You would need an adaptor plate to mount it to the clutch housing to start with. If that part is not much trouble for you then your home free.
Zyta
Posted: 20 Jan 2010 at 11:10am |
That wouldn't be to hard to fabricate. Do you think the flywheel and clutch would fit inside the CA?
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 20 Jan 2010 at 1:30pm |
Jim anythings possible .I really think a 160 engine could probably be upgraded to run just as close a hp number as a mildly modified 226
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4575 |
Posted: 20 Jan 2010 at 1:54pm |
Jim. Your supposed to be working and not daydreaming !!! The 160 from a D-15 series II is popular in the CA's. May be hard to find and for sure are expensive to rebuild since the 160 parts are only supposed to be available from AGCO. Its a bolt in.
Zyta
Posted: 20 Jan 2010 at 2:09pm |
Calvin, between phone calls and working on the computer all day you get a little time to dream/ask questions and to see what your doing....I never take a lunch..
Jim
Burgie
Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Posted: 21 Jan 2010 at 7:34am |
The G160 is the best. Bored and stroked, it is a BAD unit. You don`t have the weight of the 226 and it bolts in.
"Burgie"
Dick L
Posted: 21 Jan 2010 at 8:40am |
You would need to use the CA flywheel to match the starter to the ring gear on the flywheel or machine dowm the 226 flywheel to accept the CA ring gear and clear the starter head. You get to machine and re balance the flywheel which ever way you go.
The starter would have to be moved forward the the thickness of the adaptor plate.
Just a lot of little details that you wouldn't want to miss.
You would have to build an adaptor to bolt the CA front fast.
I thought about it some in the past but that is far as I will ever get to trying it.
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 920 |
Posted: 21 Jan 2010 at 12:21pm |
As far as flywheels go I think the easiest route is to redrill the CA flywheel to fit the 226 crank and also machine a steel spacer the same thickness as your adaptor plate so that the starter bendix would align properly with the ring gear. Kip
HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
