d17 pulling clutch |
graveyard
Topic: d17 pulling clutchPosted: 06 Feb 2013 at 8:42pm |
have a d17 with a gleaner z that has been stroked a little looking for a stonger clutch. In the northern ky area. does anyone know of someone is this area that can rebuild one or have a new clutch thanks!!!
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2095 |
Posted: 06 Feb 2013 at 8:48pm |
you could search some if wi50's posts he is building 2 disc clutches the require no other mods other than the flywheel
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Mrgoodwrench
Posted: 06 Feb 2013 at 8:52pm |
wi50
Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
Posted: 06 Feb 2013 at 9:30pm |
A D17 has an 11" clutch and will hold a lot more than the WC-WD45 10" clutch will.
Call Theobold Custom Manufacturing in Staceyville Iowa and they should have a core to build or send them yours. Just tell them it's for a pulling application and they will use heavier springs to increase the plate load. They're fast and reasonable. Verry likely not needed and more work or money than most are willing to do, a twin disc is much easier to build for a D17 because the ring gear is on the engine side of the flywheel and much larger in diameter. It would be verry easy to use your existing flywheel and make a twin disc setup. With either cutting the flywheel flat and putting the pressure plate on stands. Or one could cut the step deeper and machinin 3 slots through the flywheel and makeing the floater plate with 3 drivers on it. I'd run a flat flywheel and pot the plate on stands if doing it. |
wrbewley
Joined: 02 Dec 2010 Location: New Haven, Ky Points: 43 |
Posted: 09 Feb 2013 at 2:16pm |
Go to KY clutch in Brooks, Ky it's about 10 miles south of Louisville on I65. Talk to Chris tell him your plans and will build one for you, he built mine for my D17 with a gleaner c engine.
unstylish_
Joined: 19 Dec 2012 Location: southwestern Mi Points: 129 |
Posted: 09 Feb 2013 at 7:57pm |
Hey bewley. What do you have for mm chassis pulling stuff laying around ??
SuperM74
Joined: 27 Jan 2013 Location: Hustonville,Ky Points: 22 |
Posted: 12 Feb 2013 at 5:19pm |
Kennys Pulling Parts, in Waynesburg, Ky. He builds a lot of steel flywheels, single, dual, and i think a few triple setups. 606 379 7490
KGood
Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
Posted: 14 Feb 2013 at 9:00am |
I would think a button clutch would hold just fine for a mildly stroked engine. You could put a little stronger springs in it to but you really don't need to have anything special. We ran a D17 with 6 1/8" stroke and 4 1/2" bore up to 6000# class with a button disc and I don't remember if we even put stronger springs in or not but you should while you have it apart.
graveyard
Posted: 14 Feb 2013 at 11:24am |
Thanks everyone for the info. Going with a new clutch our local o'reillys ordered me a heavy duty clutch from howard industries in indiana. SHould hold well , my old clutch wouldnt hold in second mainly from wear.
