plow for sale |
Chris WI
Joined: 19 Sep 2009 Location: Cross Plains WI Points: 211 |
Topic: plow for salePosted: 15 Jan 2010 at 11:07am |
I have a 4-14 allis plow for sale works good, I used it this past fall. everything sand blasted and painted but coulters and tail lift wheel. also has the gauge wheel. it is the age of wd45-early D-17 I think that makes it a 60 series. make offer?
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1960 |
Posted: 15 Jan 2010 at 11:33am |
Wish I could find a five bottom like that for my WD45 diesel and D17 Diesel.
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 15 Jan 2010 at 1:24pm |
hey chris would you email me a few close-ups of the gauge wheel and bracket/clamp on that thing? i am going to try to fabricate one for mine if i can't find another one
Butch(OH)
Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Posted: 15 Jan 2010 at 3:02pm |
Hey! I need a complete gauge wheel asembly like that too! Close to Ohio would be nice.
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 15 Jan 2010 at 4:19pm |
Butch - you and me both. Have two with them but would like one to go on that 3-16's 73 I bought last summer.
Chris - that slanted mainframe beam going out for the 4th bottom on your plow is the most tell-tale way to determine it's a Model 64 plow. The smaller square tube cross brace is the next way. The slanted shank coulters I believe could have appeared on early 70 series plows but were a feature of the 60 series. Mike |
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Butch(OH)
Posted: 15 Jan 2010 at 4:31pm |
Got so excited about the gauge wheel I forgot the model question. The slant beam plow models are 60-non adjustable frame, 70-adjustable frame shear bolt, 80-adjustable frame spring trip. Cant tell for sure because where I need to see isnt visable but looks like non adjustable frame so it is a 64 |
Rfdeere
Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
Posted: 15 Jan 2010 at 4:34pm |
When did they switch from the short beaming screw to the long one? I have a 63 with the short one like on a 53, but you guys say this is a 60 series too. Did it get switched in the middle of the series? And how do you tell this 64 from a 74?
http://www.rumelyallis.com |
John D
Joined: 12 Sep 2009 Location: Sherman, IL Points: 360 |
Posted: 15 Jan 2010 at 4:40pm |
here is a picture (if I do this posting right) of my model 73 with wheel assembly on it - if this helps any. The wheel slides up and down inside a piece of box steel with a set bolt in the middle of it.
http://i131.photobucket.com/albums/p293/jd1783/Model73plow.jpg |
Skyhighballoon(MO)
Posted: 15 Jan 2010 at 4:42pm |
Rfdeere - the longer beaming screw on the 63 is due to it being a 4 bottom vs. 3 bottom I beleive.
To tell the 64 vs the 74 just look at the photo above of the 84 sitting next to it (ignore the spring trip bottoms and it pretend it's a 74). Some items to spot: * 70 series has adjustable frame as Butch points out. All the main beams are squared off. If you look closely you can see some double bolts where the frame beams overlap and bolt together. That's where you unbolt and adjust from 14 to 16 & back. * 74 has larger square tube cross brace that I mentioned above * 70 series has taller plow beams for more trash clearance * later 70 series has coulter shafts at 90 degree angles like in the photos * beaming screw mounts differently in back on 74 Mike |
John D
Posted: 15 Jan 2010 at 4:46pm |
This time for sure! Before: ![]() After: ![]() |
Butch(OH)
Posted: 15 Jan 2010 at 4:48pm |
Nope The picture isnt helping, you need to unbolt it and send it this way, LOL
phil
Posted: 17 Jan 2010 at 10:53am |
looking for a set for my 190 xt. are they to small?
Gerald J.
Posted: 17 Jan 2010 at 12:44pm |
Plow coulters were used for many different frames, just like some bottoms. There were fewer coulter models than plow frame variations. Most clamped on the plow beam in front of the bottom. And while the 2000 series plow is taller there is a bar just above the plow moldboard sticking forward to carry the standard coulters that could have been on a 60, 70, or 80 plow frame.
Gerald J. |
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 797 |
Posted: 21 Jan 2010 at 6:20pm |
Where in Wisconsin are you and what were you looking to get out of the 4 bottom plow?
Lester
Posted: 03 Feb 2010 at 9:59am |
My booklet shows that the 1960 model 74 has the smaller square tube and no square tube on the pre 1960 models. They are the high clearance models !
