HD5 Problem |
Mktlne
Topic: HD5 ProblemPosted: 04 Jan 2013 at 9:50pm |
Hi! New to forum just purchased a HD5B and I have a problem with left track not wanting to work, looking in the steering clutch resevoir 1/4 full of liquid is this norm for 1946 or is it supposed to be dry. I am assuming the clutch is froze up. Any help would be appreciated.
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 04 Jan 2013 at 11:00pm |
The clutch compartment should be dry and free of rust on the clutches. I have one to redo and has both clutches stuck.
gemdozer
Posted: 05 Jan 2013 at 5:00am |
The HD5 stering cluch are dry just remove the plug under housing for draining
Mktlne
Posted: 05 Jan 2013 at 6:59am |
Thanks for the reply
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42268 |
Posted: 05 Jan 2013 at 1:07pm |
On bottom of tractor is a 3/4" pipe plug . This is to be left open as a case drain unless working in wet location. Inside of case also seems to attract mice and collect things which will block drain hole - creating problems.
Also on underside of machine is a bolt which is used to support the brake band to keep it from dragging on brake-clutch drum. If the clutch will not release - removal and clean up of clutch is the option .
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 06 Jan 2013 at 11:19am |
On page 8 of this forum there is a posting "What is the tensile strength of a mouse nest" This tells about the steering clutch problem on my machine. The posting date was 19 August,2012
