excessive white smoke
JRM914 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JRM914 Quote  Post ReplyReply Direct Link To This Post Topic: excessive white smoke
    Posted: 06 Dec 2012 at 1:06pm
hello I have a FL40  Allis fork lift with a Buda G-153 engine and it has a  carb it started smoking real bad it would fill a 2500 sq ft building in seconds so you could'nt see 20 ft away the engine runs ok no engine miss dead cylinder  It had a coolant smell to me so I pulled the head expecting to see a blown head gasket it wasnt blown sent the head to machine shop had it pressure checked it is ok.  What can be the problem? Only other thing to note is it is a bit overfull on oil not with antifreeze but gas smell  this thing is not used very often and short running times that is what I contribute the over fill and smell in oil
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2012 at 1:35pm
Do you have an external fuel pump on the side of the engine? Sounds like the diaphragm went out and thinned the oil down until it started passing oil past the rings.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote JRM914 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2012 at 1:52pm
thank you we were thinking that also since there was no head problem the smoke i thought had a antifreeze smell maybe just in my head.  thanks again
This page was generated in 0.297 seconds.
