Allis-Chalmers Grader
Swifthawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swifthawk Quote  Post ReplyReply Direct Link To This Post Topic: Allis-Chalmers Grader
    Posted: 28 Oct 2012 at 12:30pm
uploads/7327/Grader_2.jpguploads/7327/Grader_3.jpguploads/7327/Grader.jpg
Can anyone tell me what kind of model this grader is? i have never seen one like this before. Thanks.
James Coons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 12:51pm
Looks like a 41T.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swifthawk Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 3:37pm
This is the only one I have seen with the motor down behind the blade . I could never find a picture of it in any Allis Chalmers book.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 5:08pm
According to "Allis Chalmers Construction Machinery and Industrial Equipment"  by Norm Swinford
it appears to be a 42T. T for tandem axle.  Powered by UM engine.
the 54T looks similiar but is powered by the K engine.  cab was standard equip where as on 42T was optional.
both models produced from approx 1931-1940
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 5:10pm
AC went though several variants of that design.  Here is a picture of its big brother that I found online.
And here is a picture of the older single drive axle model. (This one is dad's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 5:15pm
Thanks for the correction.  I recently moved and haven't found the box with my Allis books yet! Ouch
Edited by James Coons - 28 Oct 2012 at 5:21pm
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 7:49pm
The 42T picture was taken at the GOTO in Marshalltown IA in 1998. I talked to the owner and he said that he drove it 60 miles to the show.
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 6:47am
What drives all the actuators? How does power get to that box near the steering column?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 9:06am
Looks like front drive from engine, by what means - unsure - belt - chain or ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 10:35am
it drives off the front crankshaft via gear boxes and shafts to power the control box.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 11:49am
I have pictures of a restored 1937 model with single axle and dual wheels and a cab. All the controls appear to be hand cranked.
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2013 at 3:52pm
Both models sure have a low center of gravity. The owner driving his grader sixty miles to the show was mentioned over the PA (or by someone during discussions in main big tent).
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2013 at 11:49am
Hi guys-I just picked up this grader (1939 41S) this weekend.  I need several right angle gear boxes for the drive mechanism.
Does anyone know where one might of these graders might be in a boneyard?
Also, a parts book would be helpful
Also, 5 inch wide by 20 split rims
Thanks.
    Edited by nowaktj - 18 Nov 2013 at 4:59pm
    Ages Cat View Drop Down
    Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2013 at 4:11pm
    Congratulations, Terry. Looks like a keeper!!!!!!!
    This page was generated in 1.988 seconds.
