5.9 cummins flywheel
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Topic: 5.9 cummins flywheel
    Posted: 28 Oct 2012 at 2:31pm
lookin for a 5.9 flywheel to retrofit into a allis tractor 1 1/4 input 97 motor  Robert Clark  217 712 0984    zero61@frontier.com    THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 2:31pm
needs to be a STEEL flywheel.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 3:19pm
Have u checked the Dodge Cummins Forum, lot of good stuff over there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 4:45pm
Tried to register what a pain........
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 5:08pm
It is aggrivating, but worth it, lot of stuff
WildBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 8:07pm
Pulloff.com is full of 5.9 parts . Scheid diesel has parts usually . Shud be able to find one . Take it easy
Allis fan for life !   B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2012 at 3:43am
Have u checked out other makes like a Chevy? Mack always has good ideas, he put a Chevy on his AC crank, alot cheaper - but theres got to be a used Cummins around as popular as they are
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2012 at 9:47am
Had Chevy flywheel on my 301might have to adapt it...
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2012 at 9:38pm
Try Carl at Atlas Tractor in Blane MN. He makes SFI flywheel and clutch assemblies and would have the patterns for the Cummins.
You may have to do just a little homework though as far as positioning the disc or discs and pilot berring from the crankshaft flange. I've ran into issues doing this kind of thing where the distance from crank flange to rear of block, distance from bellhousung to input shaft splines and pilot area all need to be figured out. Hopefully it's all easy for your application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2012 at 7:59pm
Had to do the same measures when i putin a twinn disc clutch with a Chevy flywheel and adapter
CTD03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2012 at 12:16pm
Try competition diesel forum. Great place for truck parts diesel related.
Better yet I deal with this guy his name is Jeff
mumaudiesel.com.
Edited by CTD03 - 31 Oct 2012 at 12:29pm
1961 D17
(sold)1968 190xt
This page was generated in 0.219 seconds.
