Wd 45 help!!!! |
Page 12> |
Allis-chalmers wd45
Joined: 11 Apr 2012 Location: Newton, Nj Points: 1917 |
Topic: Wd 45 help!!!!Posted: 23 Sep 2012 at 8:35am |
Guys I need to really get some plowing done and my tractor is just going downhill fast!! I can't get it to run right it seems like its miss firing real bad I replaced all the plugs and it ran good but only for a day then it's back to runninng like complete crap! What do I need to do to get its going good can someone help me fix the timing? Anything thanks!
jlogli
Joined: 12 Oct 2011 Location: Stockport, IA Points: 862 |
Posted: 23 Sep 2012 at 8:38am |
Change the wires, cap, rotor and condenser.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6088 |
Posted: 23 Sep 2012 at 9:28am |
I second that. If it's missing, changing plugs may have an impact, but more likely that some other component of the ignition system is at primary fault. The wires may be old, dry, and tired, and leaking... but even more likely, the cap may have carbon tracks that the spark energy is following to ground, rather than the plug gap. Even more likely that the contact points are pitted, contact spring soft and weak, and condenser dried out. The point cam may be well-worn, and the distributor shaft may be sloppy in the bushing. You may even have a coil that's developing an internal short, or a coil power wire that's corroded internally and failing.
A proper 'tune up', would be to pull it all off, replace all the parts from the plugs to the distributor shaft, and check that distributor shaft to make sure it doesn't flop around... make sure the advance weights in the base of the distributor are functioning properly, and that you don't have a loose screw in the breaker plate, then reassemble, set the point gap, then adjust timing per spec, it should be much happier. Can you describe it's running attitude in greater detail? does it miss more when under load, or at higher speed an lighter load? |
Dipstick In
Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
Posted: 23 Sep 2012 at 9:31am |
And if that doesn't fixit, maybe look for dirt or rust in the fuel system. Had that happen in my 49 WD under load.
Allis-chalmers wd45
Posted: 23 Sep 2012 at 10:46am |
It has a brand new distributor , new internals , new plugs , new woring, I don't know what else. It sounds like a John Deere 2 cylinder it's horrible and barely runs I think she may be dead..
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 23 Sep 2012 at 10:51am |
Old tractors do not like today's gas. I'm haveing the same problems with several of mine.
Put in fresh gas and they run fine for a while, let them sit for a month and I have the problem.
AlVee
Posted: 23 Sep 2012 at 10:57am |
I would pull the plugs again and make sure they all look good I have seen were they get carbon chunks wedged in the plug after a good tune up if they all look good then yes check the fuel system also make sure you didn't loose an intake manifold gasket that will make them run bad also.
Stan IL&TN
I'd try fresh gas first then maybe a new coil as you have replaced everything else. If after all this and it still runs poorly then It may be time to do a compression test or look for a sticking valve.
1957 WD45 dad's first AC
dave63
Joined: 01 Feb 2011 Location: Lineboro Md Points: 2382 |
Posted: 23 Sep 2012 at 11:00am |
I have put new Champian plugs in that only lasted a day or two. I switched to autolights.
You realy need to do some basic trouble shooting to find the problem. Just don't assume that becouse the parts are new thay are good.
The universal answer to all questions is yes, how much do you want to spend?
DaveKamp
Posted: 23 Sep 2012 at 11:13am |
Boy, Dave hit it right on the head there... brand new stuff, right out of the box, worse than the 20-year old parts I'd taken out.
Particularly condensers and points. I'll second the fuel system comment, with particular attention to the passageway from the tank into the drain petcock, and also the catch screen located in the thread-in fitting on the side of the carb body... And finally... drain ALL the fuel, and put in new fuel... preferably, as late in the fall as you can (winter formulations). Always remember that ethanol does not naturally MIX with gasoline- it's just 'in suspension', and will settle. It is also hygroscopic... will absorb moisture. Take a glass pickle jar, and pour in a quart of modern gasoline, cap it, and put it on a shelf for two months, and you'll see layers appear... water on the bottom, supersaturated ethanol above that, then straight ethanol, then gasoline. Guess which part goes to the carbeurator first... If it sounds like a two cyl, then lift a plug wire and see if the engine speed changes. If it does, put it back, and move to the next. When it doesn't change, THAT is the BAD cylinder. If you have TWO bad cyls, is it possible that the wires are reversed? these old gals run incredibly well on just two... my 'oily B' starts and runs great with two hitting, and the other two belching oil... gotta wear an old hat, because it RAINS on me every time I move it. (needs sleeves, pistons, and rings BAD). |
ALinIL
Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
Posted: 23 Sep 2012 at 6:05pm |
wd45 - Since you have done so much, I think you need to trouble shoot and determine the problem. 1st - take a screwdriver and ground out one plug at a time to determine which cylinder is missing or if its a random miss. If its random it could be electrical or fuel. Then go to the next next step. Random could go either way. Electrical could be condenser or a intermittent short or a coil going bad. You might also dress the points as they might have oxidized. Next would be to check the fuel system. I could go on, but you get the idea. Just throwing parts at it is not the most cost effective procedure to follow.
allischalmerguy
Joined: 11 Sep 2009 Location: Deep River, IA Points: 2893 |
Posted: 23 Sep 2012 at 6:27pm |
I had a loose wire on the distrubutor that came from the coil...if I remember right, not the big wire that goes to the middle of the dist. cap, but the small wire was loose...it missed alot and even died...at times..finally figured it out.
Ted in NE-OH
Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Posted: 23 Sep 2012 at 6:32pm |
Where ate you at maybe a forum member is close that could help you.
Brian G. NY
Posted: 23 Sep 2012 at 8:46pm |
Another possibility if all else fails...shoot some carburetor cleaner around the manifold intake ports while the tractor is running. It it smooths out, you may have a bad gasket and/or eroded manafold or head.
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 23 Sep 2012 at 8:56pm |
check manifold gaskets, and make sure you have a good battery (if you have a distributor not a magneto)....two things that have caused similar problems for me but were the last things I checked
Allis-chalmers wd45
Posted: 23 Sep 2012 at 9:51pm |
Thnk you guys so much !! I'm gonna give it a
Ll a try tomorrow! |
Allis-chalmers wd45
Posted: 24 Sep 2012 at 5:24pm |
Well I tried everything today guys different coil, cleaned the carb, put in new fuel, tried a different sediment bowl, checked the wires , i don't know what else to do I give up on her
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 24 Sep 2012 at 5:41pm |
Justin did you check the manifold gaskets?
dannyraddatz
Joined: 12 Sep 2009 Location: Plainfield, Ill Points: 848 |
Posted: 24 Sep 2012 at 5:47pm |
Justin,
One member asked if some one close could help you? Well your profile does not give city or state where you live. Danny
Edited by dannyraddatz - 24 Sep 2012 at 5:47pm |
Danny Raddatz
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 24 Sep 2012 at 7:35pm |
dont know if you cked.for it but,ck.the coil where the primary wire plugs into it.ck.the wire on the dist.(coil wire) if you have any green powdery formatoin.you have a built in resistor in that circut.and you get some erratic symptons...
j.w.freck
Posted: 24 Sep 2012 at 7:38pm |
lso might add,i use the dow corning moisture inhibitor in each plug wire and the coil wire.same stuff we used it on aircraft plugs.....
DaveKamp
Posted: 24 Sep 2012 at 7:54pm |
Well, if you tried everything, then you would have found the problem and fixed it. It sounds more like you solved it the easiest way known to man: Giving up. The method that seems to work best with this group, is to list all suggestions, and then go through, one suggestion at a time, and check as suggested, test accordingly, and report the results... even those things you noticed, but thought insignificant... of each test. Then read the posts we render in concert with your observations. Typically, two to three goin's round, and you'll have the problem licked. If you're satisfied to take the easy road, just post photos, price, and location, someone will relieve you of your troubles, spend five minutes fixing it, and drive it away. I would venture a good bet that over 70% of the fellows here have breathed life into a hopeless wreck, and turned it into something solid, reliable, and useful in under two days... and at least a third of those guys did it to engines that wouldn't even TURN when they got 'em. |
allischalmerguy
Posted: 24 Sep 2012 at 9:00pm |
Justin don't give up. Hang in there man. This is a learning experience. When you get her fixed you will be a better mechanic. This is a learning curve.
Allis-chalmers wd45
Posted: 24 Sep 2012 at 9:44pm |
Guys Im from northern nj, and it has a new manifold and gaskets I don't think they would be bad? I won't give up its just to addicting to keep trying! Tomorrow I'll try the other suggestions and see could the timing possible be off some?
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2422 |
Posted: 24 Sep 2012 at 9:56pm |
I sold a guy a new manifold for a WD45 once,he put it on and said that the tractor wouldn't run right.He didn't put in the 1/8 inch pipe plug in the intake side of the new manifold.He was right,it ran like crap until you plugged that hole.
DaveCinIN
Joined: 12 Sep 2009 Location: Kouts, IN Points: 629 |
Posted: 24 Sep 2012 at 9:57pm |
Did you pull the valve cover and make sure everything is okay under there? Rockers and pushrods OK? Proper clearance?
Allis-chalmers wd45
Posted: 24 Sep 2012 at 10:00pm |
I will check that tomorrow too! And I didn't check under there I'm not sure how to check that
1946 "C"
1956 "WD45" 1965 "D17" Series IV 1979 185 factory ROPS deutz allis 385 planter |
Don(MO)
Posted: 24 Sep 2012 at 10:09pm |
That's the right way to look at it! Don't let it win; You can and will get her running like a top again.
Now I'm thinking after you spayed around the intake manifold then I'd run a compression test next then I'd run a vacuum test before more parts are installed.
I learned years ago I will not get payed for parts that I put on that the tractor did not need them. lol
allischalmerguy
Posted: 24 Sep 2012 at 10:18pm |
One other thing to try...unless I missed it that someone else suggested it...this is very fast and simple to do. Take the aircleaner oil cup off (make sure you are in a clean enviornment) and try running the engine up with out that on, in case you have a plugged air inlet...ck while you have it off to see that there is nothing plugging anywhere.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34372 |
Posted: 24 Sep 2012 at 10:20pm |
AC45, Have you checked which plugs are not firing the engine? find those two offenders and switch plug wires... Might be your looking at rotation on distributer backwards... If all the things these fellows have suggested doesn't work, (which would get a normal tractor back to running) remove all the plugs and turn engine to top dead center on compression stroke and then blow air into spark plug hole... keep fingers from fan and such and listen if you hear nothing, then turn engine to TDC on # 2 cyl. do the same the to number 4 cyl and finally do number 3 cylinder. No air noise on all cylinders would be great... air coming out exhaust is burnt / warpped/ bad ex valve. If you hear air coming out intake pipe .. bad intake valve.. and if you hear air coming out of the adjoining cylinder, bad head gasket. Or air out radiator cap still bad head gasket. Had one tractor that the valve train adjusting screw opened up valve and didn't run right... another had bad intake manifold gasket and it didn't run right on two cylinders... had one with burnt chunk out of ex valve and it 'whopped' along. Had one that had a bad head gasket and it amazed me it ran as good as it did.leaked between #2&3 cyl and into radiator...
Make sure you have right point gap. should look like about the thinkness of a match book cover.
When checking gas flow, make sure you run a soup can full through the line / drain plug to make sure you have full flow... and make sure your carb settings are good and the jets are clean.
Got 190 gas that starts to be weak when inline car filter starts plugging on gas line so I blow it backwards and get rid of dirt and rust and whatever else that is in there.
Tell the fellows what town your close to in northern NJ. Maybe there is somebody close that can help. ... Good Luck.
Page 12> |
