roto baler question
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: roto baler question
    Posted: 18 Sep 2012 at 5:34pm
Why is there a letter at the end of the serial #?  The twine guides are different than the other roto balers that i have seen in the past.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2012 at 6:12pm
S Stands for standard I believe. There was a time when they made the Non-Stop and then just your standard Roto Baler. Hopefully someone else can confirm this. As for the twine guides...not sure. Something that someone had rigged up on the baler perhaps?
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2012 at 6:20pm
I looked up your serial # shown 9401 would make it a 1948 model, but that wouldn't make sense with the "S" as the fast tie models didn't come until the 1950s.
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2012 at 6:43pm
The twine guards look factory. It has a little spring that keeps tension on it. (right side of assembily)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 4:53pm
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 5:34pm
That is an aftermarket attachment.  I have seen them before.  If memory serves me right they were supposed to prevent twine catching where it would in the standuard guides.  Years ago there was a set on a baler at the show in Belmond Iowa.  They had some issues with them that day and they took them out.
As far as the S I am not sure.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2012 at 7:05pm
bump
