190xt jumping 2nd gear |
TREVMAN
Joined: 04 Jan 2010 Location: Regina,Sask,Can Points: 1635 |
Topic: 190xt jumping 2nd gearPosted: 03 Sep 2012 at 3:14pm |
I am looking at a early model 190xt that is jumping out of 2nd gear. What is this gonna look like to fix? Does the tractor require splitting and tranny rebuilding. Otherwise the tractor looks really good, but I dont need another heavy "fixer upper". We had an 185 that occasionally jumped out of third, I remmber my Dad taking off the top cover, bending the fork a bit and putting it back together, it would work for a year or so, then he would have to do it again...He seemed satidfied, but I wouldnt be...Thanks in advance for any advice, Trev.
jlogli
Joined: 12 Oct 2011 Location: Stockport, IA Points: 862 |
Posted: 03 Sep 2012 at 3:21pm |
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 03 Sep 2012 at 3:34pm |
having just fixed my gear jumper i can say this. If you are not doing this yourself it will be expensive. if you do it, it is a lot of work, not really hard, just a lot to do. You have to split at front of tranny, remove axles, bullgears, pinions, differential and pinion which is transmission main shaft. you slide out the pinion to replace the gears as they are all on it. I did not have to remove my counter shaft, all was well. I spent about $1000, with aftermarket gears from A&I and every seal and gasket and o-ring on the rear housing replaced from AGCO.
my post showing teardown pics
TREVMAN
Posted: 03 Sep 2012 at 4:01pm |
I think I'll steer clear of this one...Thanks Gentlemen, Trev.
DougG
Posted: 03 Sep 2012 at 6:10pm |
Treavman if the price is right on it , theres a few different ways to make a device to hold it in gear , the best one ive seen is a door hinge that falls behind the shift lever when put into that slot , he had a foot lever to tip it back up ,
CAL(KS)
Posted: 03 Sep 2012 at 6:18pm |
that is only a bandaid, it will get worse, and your only grinding off your shift fork.
i should mention that when i did mine i replaced: input shaft, 3rd gear and shift coller, 2nd gear, sliding gear and reverse gear. i could have probably been ok with 2nd but i didnt want to take any chances since i was already there. it was a loader tractor and had a lot of trans abuse. to just do one gear your looking at about 400$ if you use after market gear and all new gaskets and seals in rear from AGCO. AGCO gears are REALLY high
it is a lot of work but i know everything is in good shape
TREVMAN
Posted: 03 Sep 2012 at 7:44pm |
Asking price is 3200, says negotiable. Id say it had a loader on it. Looks like it has 23.1-34 rears at 30%. The tractor has a cab and new turbo. Has front weights, looks really good otherwise. Owner was forthcoming about the gear jumping when asked. I am not desperate for a tractor and I trust you guys when it comes to "surgery". I'm still thinking pass. I appreciate all replies, thanks, Trev.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 03 Sep 2012 at 8:50pm |
Mine is a recovered gear jumper. I had my mechanic neighbor fix it while I bought the parts. It seems there are a number of factors that cause it to jump out. Either way, it is quite involved. However, it does work great now that it is fixed up!
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 04 Sep 2012 at 6:18am |
I thought I read an old dealer service bulletin from the early 1970's once that talked about "torque lock" gears and shift collars to use in place of the original gears. Was I dreaming or misunderstanding what I read? This was at the auction of Don Peterson near Blooming Prairie MN some years ago after he died. There was a hay rack full of old manuals and this bulletin was in the mix somewhere. Maybe someone here can tell me what that bulletin was all about. DrAllis, Mack? Someone else?
Wink I am a Russian Bot |
