ac model B
smittyspitty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smittyspitty Quote  Post ReplyReply Direct Link To This Post Topic: ac model B
    Posted: 15 Aug 2012 at 3:30pm
I have a 1938 model B that when started it wants to run full throttle. Any ideas, when not running you can move linkage around. when running it is tight, took end off govenor housing everything was moving freely ?
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 9:21pm
Welcome to the forum, I'm supprised you haven't gotten an answer yet.
I'm not sure but i think there should be a spring on the linkage between the carb and the governer to hold it back.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 9:28pm
Give a little history of the tractor. Is this something that just started all of a sudden? Has the engine been taken apart for repairs and now won't run right. If it ran before and won't idle now, I would take a look at the governor weights. Get a Service manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smittyspitty Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 4:56pm
Thanks for the reply, the weights look good no parts fallen off or nothing. I took it to a couple of shows and it ran fine, it sat for about three weeks and then this happen ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 6:26pm
What part of PA are you in? If your in the area i may be able to look at it.
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2012 at 9:49pm
Try taking the carb off and see if the throttle shaft is free.  Next I would look and see if your throttle linkage is slipping on the shaft of your carb, and then trace the linage back to the hand control.
