HD6 final drive noise?
Tb4020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tb4020 Quote  Post ReplyReply Direct Link To This Post Topic: HD6 final drive noise?
    Posted: 13 Aug 2012 at 7:06am
Hi, new to the board! Using my HD6 yesterday and it started making noise in the right rear and slipping, I know it's probably not good but any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 9:07am
Depending on the noise , clutch slip, bad bearing - allowing the teeth to jump of reduction gears, broken axle, or ?
 Pull inspection cover on clutch housing and start there . Raise tractor so both track off the ground and see what happens to each side or the noise heard when each track is individually not powered by other side .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tb4020 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 10:39am
Almost sounds like a bearing bad and teeth jumping. I was just hoping for a silver lining.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 12:18pm
Remove the final drive drain plug from side noise and check if you have some metal pieces in oil it could be a pinion bearing
This page was generated in 0.127 seconds.
