6080 pulling tractor
allis 7045 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis 7045 Quote  Post ReplyReply Direct Link To This Post Topic: 6080 pulling tractor
    Posted: 03 Aug 2012 at 6:29pm
I was wondering what kind of stuff could I do to my 6080 Allis chalmers to make a good pulling tractor out of it but still be able to take it home and work in the field with it
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 7:58pm
I tried it with my XT and it didn't work. It was bout 175 hp and when I plowed and disced it got hot and I changed from tin wheels to cast for every pull was a pain also     Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 11:10pm
Turn the pump up is about it , but most were puttin out over 100 hp from the factory- ive heard
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 8:11am
A friend of mine used to pull at the County Fair and farm with one. I set him up with water/alcohol injection ahead of the turbo and it would make 140 to 150 HP. He always did well in a 9000 lb farm stock class but there are better choices than a 6080 for HP.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 12:02pm
A 6080 had a relatively small displacement engine that was already turbo'd and intercooled.  The opportunities to farther increase its power (reliably) are more limited than other tractors that started with larger displacement engines.
Edited by 427435 - 04 Aug 2012 at 12:02pm
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis 7045 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 6:37pm
I also have a Massey Harris 44 gas turbo charged. running on alcohol but it sat for a while.   a long while and motor stuck. also have case 1370 ac 7045 ac 170 and two 6080
This page was generated in 0.184 seconds.
