hi/lo on WD
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Topic: hi/lo on WD
    Posted: 29 Jul 2012 at 5:03pm
is it possible to put a sherman or some other hi/lo on a WD or does it only work on the WC because of the lack of hand clutch? I would like to have a little more speed for tractor rides since I'm usually running wide open and just barely keeping up, would like to keep stock tire size
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 5:31pm
  instlla SP100 COMBINE SPRING WILL NOT HURT TRACTOR EITHER
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 5:35pm
  SORRY INSTALL WAS TO  BE THE WORD an a-c service man gave us one yrs,ago  for the other colors to make them mad  never took a rear seat  MOVE OTHER FOR THEM
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 5:38pm
^ huh?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Richard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 7:10pm
The last tractor drive I was on with my 45 I was running wide open and got left in the dust.  That's not my idea of a tractor drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 7:14pm
If everybody did like our club did, you wouldn't have a problem. A stock WD45 was first in line and instructions were to follow that guy and keep some space between tractorsThumbs Up
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 7:15pm
Bigger tires would be the easiest way to get more speed, the WD45 driven back from Ashton ID to Rolog  in about 95 or 96 had 38's on it and went 18 MPH
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 7:27pm
 A WD45 with good 14.9 x 28 rear tires is supposed to do 12 mph at 1400 rpm which would translate into 14 1/2 mph at 1700 rpm wide open throttle. If you put a D17 governor spring/plunger in it, the engine speed will increase to 2000 rpm and ground speed then will be 17 mph.
