AC dealer lighted signs |
EricSWPA ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: PA Points: 292 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Jul 2012 at 9:40pm |
Sounds like a ballast issue but if the bulbs are dark at the ends you could try new bulbs ive seen old bulbs sorta light but never get bright just kinda flicker
dave63 ![]() Orange Level ![]() ![]() Joined: 01 Feb 2011 Location: Lineboro Md Points: 2382 |
Send it to me and I will fix it. BTW I will need to keep it for an undetermined amount of time. LOL
The universal answer to all questions is yes, how much do you want to spend?
Protrucker ![]() Orange Level ![]() ![]() Joined: 25 Apr 2011 Location: Broome Cnty,NY Points: 718 |
Are there starters for the bulbs? You might just need to replace those. That could be a cheap easy fix.
"ALLIS EXPRESS"
Allis Chalmers ![]() ![]() |
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
I would be rather suprised if it's 277 volt. My guess would be some parts need replacing.
NJBizValuations8 ![]() Bronze Level ![]() Joined: 16 Jul 2012 Location: USA Points: 1 |
It could be that it is a multi voltage ballast, and you will be lucky,
or it could be fixed at 277, then you have a little work to do.
allisrutledge ![]() Orange Level ![]() Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1360 |
My 3x12 works on 110 V also. Scott
Henry se/k! ![]() Orange Level ![]() Joined: 08 Mar 2010 Location: Kincaid Kansas Points: 403 |
You need a new ballest, may be new scokets for blubs and new bulbs. I have had two fixed. lately.The cost arond 300. It will work like new
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4532 |
I have the same sign and its plugged into a 120V wall outlet. It needed new bulbs when I got it. Worst case you may need new ballast if new bulbs don't light up.
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2513 |
Could be a shocking experience..............
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
I hate to say it, but it might be better to have an electrician look at it. I know we're all DIY kinda guys but this might be a case where one wrong move could screw up your sign.
AGCO My Allis Gleaner Company
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Welllllllllll? If I were there, I would try some things, but since it is electricity, I don't think I want to talk you through it over the web. Can you post some pics of the ballast?
Still in use:
KurtDE ![]() Bronze Level ![]() ![]() Joined: 19 Sep 2009 Location: Hilton New York Points: 83 |
I Tried to read the label on the ballast but most of of it is missing and what is left is unreadable. I tried all the tubes in the spot that the 2 would partially light and all 6 tubes light the same so I think they are good. any more suggestions?
Signs can be any voltage, from 120Vac to typicality 277V. There should be a tag on the ballast somewhere that tells you what input voltage it is looking for. It could be that it is a multi voltage ballast, and you will be lucky, or it could be fixed at 277, then you have a little work to do. Once you know what voltage you are looking for, then we can help you out. It could also be that the dealer just didn't put new bulbs in for the last few years, since they knew they were closing, and the bulbs are bad, but let's not guess, till we know the input voltage.
Still in use:
I acquired a 3x 12 AC lighted sign a while back. and just dug it out of storage so I can hang it in my new barn. My Question is what voltage did these signs use? I tried is on 110v but only 2 of the 6 foot tubes partially light. any body know anything about these type of signs?
