wd45 starter
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: wd45 starter
    Posted: 25 Jun 2012 at 6:02pm
Starter spins but doesnt engage the ring.
Pulled starter, ring looks fine.  When I engage the starter, the gear on it spins, but it is supposed to move forward as well to engage the ring, correct?  Well it isnt...
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 9:52pm
That is how it suppose to work!
Can you turn the gear by hand? and resistance?
The force of the rotation should spin it in to engage.
Bob
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 10:04pm
Sometimes there is a burr that the gear hangs up on. You may need to use a Dremel grinder to remove the burr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 10:55pm
Sometimes the bendix needs cleaning and a light application of dry film lube. It is probably a burr as mentioned or some grease and dirt holding the gear back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 12:17am
Because it is an "inertia" bendix,it must be free to spiral down the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 3:43am
Bob
Didnt try to spin it manually, it does spin when powered up...but doesnt travel down the shaft.
Thanks guys, will check for a burr or the like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 6:37am
Use some kind of cleaning agent (brake clean, carb clean) to clean the crud and sprinkle some graphite on it. Don't oil or grease the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 8:30am
Never oil a bendix drive! Do as Tuck said. Clean the drive with Brakekleen and dust it with  graphite spray. Good to go. If oil starts slinging into the starter motor, you're gonna have a mucky gooy mess inside the motor that you don't want.
