HD6G Main Clutch replace
Red logger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red logger Quote  Post ReplyReply Direct Link To This Post Topic: HD6G Main Clutch replace
    Posted: 13 Jun 2012 at 7:05pm
 I recently became the proud owner of a Hd6G track loader. After a day of standing on my head adjusting the clutch, I have come to the conclusion that it is to the limit of adjustment. Question is how do you remove the clutch? Do you have to take the engine
and clutch out as a unit? Or can the clutch and housing be unbolted and lifted out like a Cat? Any direction would be much appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 8:19pm
Should be able to service in the machine , remove drive shaft, remove bellhousing bolts and linkage and lift out then access to clutch unit should be obtained.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red logger Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 9:30am
Thanks Coke in MN
