AC 6060 PTO Problem
AC Nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Topic: AC 6060 PTO Problem
    Posted: 04 Jun 2012 at 9:17am
What I failed to mention in my first post (my PTO doesn't engage), is that when I first started it up on the baler, I wasn't accustomed to the two lever PTO engagement process. I think the right handle was in "engage" mode when i pulled up the left shaft it ground a little like I was switching a gear w/o the clutch. I assume I sheared the bolt on the bearing forks?
