HELP with allis 180
tbstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbstock Quote  Post ReplyReply Direct Link To This Post Topic: HELP with allis 180
    Posted: 31 May 2012 at 8:01am
I have a 180 gas that we just had to replace the fuel pump on.  We also changed the spark plugs.   I went to use it for the first time yesterday to mow hay and she was not running right, she seemed to not have much power and you could hear the motor was having to work very hard just to keep her at 2000 RPM's.  The tractor also seemed to heat up very fast and backfired flames out the exhaust if you tried to run her to hard.   Any ideas of what it could be?  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2012 at 8:49am
Timing sounds retarded. Mixture could be too lean also
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2012 at 8:58am
You have two of the plug wires crossed. Pull one at a time while it's running and find the 2 that don't seem to make a difference when pulled. Switch them around and go to work.Don't mess with the timing or carb settings till you check this out since the only thing changed that would effect how it runs was the spark plugs.
Edited by CTuckerNWIL - 31 May 2012 at 9:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbstock Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2012 at 10:09am
Thank you so much for the ideas. I will go try that now.
