D-14 engine clutch
mherndon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Topic: D-14 engine clutch
    Posted: 30 Apr 2012 at 4:45am
My clutch just started slipping. I opened the inspection cap at bottom of tractor and thought I found a rats nest. Could this have been clutch debrie? I cleaned it out, and everything was dry. I thought the person i bought it from may have been hiding a leak. I was trying to adjust the clutch, but service book I have is not clear. Please explain how to adjust clutch and is it too late if it has started slipping?
Thanks,
D-15, Old dealer in Smithville, TN
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 7:46am
If there is free travel in clutch pedal might as well split it.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:25am
When I got my '57 D-14 the entire bell housing was one huge mouse house ! including the area in the starter drive !! arrghh...
Just split it to replace the ringgear. not to bad,well the second time....
Search for 'D-14 clutch' here and you'll get a few great hits or email me and I'll fill you in on the fun you can have.
better to learn from my mistakes than make the same ones yourself !!
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:47am
when you press the clutch pedal how far does it move before you feel resistance from the pressure plate springs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 10:55am
Probably 1.5 to 2".
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 11:02am
Just got a price of $275.00 from local parts store for clutch, pressure plate, & throw out bearing. All this to just pickup, no shipping. Have not checked online, but shipping would be high I suspect. Is that competitive? With getting my flywheel turned, should this get me going?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 11:04am
When you look up thru the inspection hole in bottom of torque tube, how far are fingers from throwout bearing with clutch pedal retracted? Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 11:10am
  Is it a greasable throwout bearing?You will be happier with a clutch and pressure plate from Rick Corder on here. Many aftermarket clutches are not correct when assembled in tractor. The disc is too thick, causing the release fingers to be down or too far forward. That means the pedal has to be adjusted almost all the way out. After a little wear, the fingers will be touching the throwout bearing. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 11:16am
Is it better with sealed or greasable bearings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 11:25am
I am not at the tractor now. 125 miles away in Jamestown.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 11:28am
I like the greasable bearing. About 35 dollars from Motion Industries. One without it is about 20 dollars if I remember correctly. HTH Tracy Martin
