Cylinder rebuild tool |
KRAKMT
Topic: Cylinder rebuild toolPosted: 29 Apr 2012 at 1:07pm |
Does anyone have a design for making a spanner wrench for removing the end nut from the cylinders of a 715 b backhoe?
These are the lifts that need some new guts- the ends have three notches- Can weld something up but wondering if someone has perfected a design and would like to share... ![]() Edited by KRAKMT - 29 Apr 2012 at 1:08pm |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42279 |
Posted: 29 Apr 2012 at 2:18pm |
I used a 36" pipe wrench .
My lift cylinders have been no problem but the hoe cylinders I have had to replace one piston and one of the end seal glands. The gland or part under that locking ring i got from Minnpar but the piston i made out of aluminum to match the cast iron one that had worn and chipped area. |
jnicol6600
Joined: 02 Jul 2011 Location: Sullivan Co. IN Points: 174 |
Posted: 29 Apr 2012 at 7:37pm |
I used to use a big punch and a BFH on logging equipment.
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 30 Apr 2012 at 6:22am |
Strap wrench or chain wrench would do less damage to cyl.
Coke-in-MN
Posted: 30 Apr 2012 at 9:16am |
Cast Iron cap with internal threads , locks the gland into cylinder , is just a end-cap and has no other purpose . Needs to be tight to hold the gland but does not seal or hold pressure or act on shaft .
