6080 crankshaft bearing support
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Topic: 6080 crankshaft bearing support
    Posted: 26 Apr 2012 at 11:49am
  Getting noise from front bearing support on 6080   Greased it and comes back after a few days   I would like to put  a new bearing in it looked at parts breakdown   Wondering if or how you shim it   and is it a special bearing or can I get replacement at Napa    Thank You  Gary
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 12:09pm
I replaced mine on my 6060 some years ago.  I got a bearing from a local supplier I think.   I have had the pin that hold the bearing cup (or what ever it is that holds the outer race) shear off in the past and it made a funny sound that greasing made go away but came back shortly after.  Shim the bearing thrust allowance by the service manual with shims.
