Wd45 rebuild how hard?
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 rebuild how hard?
    Posted: 23 Apr 2012 at 9:26pm
How much of a job is it going to be to rebuild my wd45 ?
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 9:35pm
not to bad make sure you have a allis service manual not an i.t. manual they are to veg
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 9:39pm
Okay I'll have to pick one up
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 8:36am
Assuming it's not your first overhaul it's not bad. It has wet sleeves make sure the counter bores at the top and the O-ring sealing areas at the bottom of the block are clean and smooth. The front and rear of the pan gasket can be tricky to get sealed but do a search and there are several posts about that. Otherwise it's pretty straight foward stuff. Good Luck.
AGCO My Allis Gleaner Company
