D 17 questions
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Topic: D 17 questions
    Posted: 11 Apr 2012 at 8:38pm
This might get a little long so I apologize in advance. I have 2 questions about my D-17 ser I.
1. Using it today to spread "fertilizer" and she started to run a little rough. Pull the choke out about 2/3 to 3/4 and she runs better. Thought it might be a fuel issue so I checked the sediment bowl and all was ok. Took line off at carb and seemed to be a good flow so I put it all back together. Still runs rough. I'm thinkin' something carb related but what I know about carbs could fit in a thimble with room left over. Any thought what I should look at next?
2. I want to put a fender mount radio on. System is + ground. Assuming that the radio isn't grounded through the mounting plate, can I just run wires direct from battery to radio- + wire to + term and - wire to - term? ( of course there will be a fuse on the + side)
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:00pm
Remove the plug at the bottom of the carb, and let the gas flow through it into a bucket for 3-5 minutes to check fuel flow. You should have a steady flow at a rate about the size of a pencil.
I think you will find that the radio has 1 wire and is grounded through the case. You could isolate the case from the tractor and add a wire to the case and connect that way.
 Bob
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:01pm
 You need to remove ,clean, and reassemble your carb with a kit from a vendor here, If you really want this radio , change your tractor to a negative ground, swap the cables from the battery opposite, reflash the regulator/ generator, and swap the terminal connections to your ammeter. I don't think I left anything out except that somewhere on your radio there may be a cover with differant wire connections for  pos or neg ground, your chioce..... check that first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:05pm
Swap wires on the coil also.
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:07pm
Thanks for the replies so far guys! 1 thing I forgot to mention is the radio has 2 wires out the back- 1 red + and 1 black -. That's why I'm thinking that if I hook to batt I can use it. I plan on checking w/ a continuity tester to make sure that the case isn't a ground before I hook it up.
