All-Crop Parts needed
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: All-Crop Parts needed
    Posted: 10 Apr 2012 at 8:04pm
Hi All,
Need part 513834. Its off a 66. its the long metal shield that rests on top of the sickle bar mount.
Also, need 504196. Left side header divider bottom - 60/66.
Thanks
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 10:16pm
Tom, would the header divider bottom happen to be the same one I posted here?  I don't believe it's the bottom, but I thought it was worth asking.  http://allischalmers.com/forum/forum_posts.asp?TID=38995&PID=295995 .  If not, I think we have another similar piece that may be what you need... don't have the parts book in front of me right now to confirm.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 2:42am
what would you give me for a whole combine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 4:59am
Almost. Thats the bottom for the other side.  Need the other one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 5:00am
Undieing gratitude!Wink
Edited by TomYaz - 11 Apr 2012 at 5:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 12:55pm
Is the bottom for the side you need about half the width of the one I show in the photos?  If so, I think we may have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 3:58pm
Yep that sounds right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 7:08pm
Am I getting warmer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 7:37pm
Yeah that its BUT there shouldnt be that side piece on it. (first photo)  The welded on piece on the bottom is not good. Keep that thought.
Turns out I also now need some three prong guards.... two of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 8:09pm
Tom, I assume you're meaning the smaller of the two parts I show.  If so, the side piece is part of the same piece of sheet metal that makes the bottom and other smaller side.  And the jury's still out on whether that piece is welded... it has a bolt at the front, and 50 years of dirt and grime at the rear... can't tell where/if it's welded.  I'm not sure which All Crop these came from... they may be from Grandpa's oldest machine which seems to have some differences from the other 60 / 66's he had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 7:48pm
Tom, you've probably found what you need by now, but in case it matters, that bottom piece was not welded.  In fact, it looks original... it has factory looking countersunk holes at both ends that match factory looking holes in the sheetmetal parts.  Looks like a wear plate similar to what a sickle mower shoe would have.  Maybe this didn't come off an All-Crop!?!  Or maybe my Grandpa or someone else just did a nice job of fabricating this piece.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 8:01am
Perhaps it is OEM!  Must be a very early 60. The other piece sure looks early.
This page was generated in 0.136 seconds.
