wd 45
jkoepke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkoepke Quote  Post ReplyReply Direct Link To This Post Topic: wd 45
    Posted: 01 Apr 2012 at 9:02pm
does this look like it is off a wd45 has a tsx 464 carb on it
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 9:57pm
I would say yes.
1954 WD45 NF "Iron Tater"
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkoepke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 10:19pm
thanks for the reply
Do you know if some of the wd manifolds are different? I have noticed some of them at the second bolt hole in has a split in the casting between the intake and exhaust. Mine does not  have that and it has cracked at both places.  I need to get a new one just wondering if one with the split casting will fit on mine, thank you
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 6:40am
if it is for a 201 or 226 engine it will fit.
