power shift wheels
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: power shift wheels
    Posted: 17 Mar 2012 at 3:37pm
who all uses this option? how can I keep the bolts lubed up so they loosen and tighten easily? sorry guys, have a lot of questions today for some reason
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 3:48pm
There are no bolts to loosen and tighten. The cams have to lock up tight or the wheel will walk around on you. To loosen the cams, start with the top, then the 2 side by side, then the bottom. Tighten in the reverse order.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 7:26pm
It depends on what tractor you are talking about. On my D17 IV there are two wheel stops that must be removed and they did away with the fussy cams. There is four bolts to loosen instead. My father was even got caught off guard alittle because he was used to the older style. The wheels are a dream to adjust. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 7:51pm
S/N: WD234847
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 7:59pm
thats what i meant. they like to seize up. Lithium grease cure this? PB doesnt do to them and im tired of having to put the cheater pipe on em to loosen em up
German Shepherd dad
#WD234847
#WD88193
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:31pm
take them apart, clean them and grease them up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 9:16pm
I use a 24 in pipe wrench on the wheel wrench. Never needed a cheater:) I have heard "never sieze" works. I have never used it. I guess I haven't moved my wheels on the 45 for a long time. They are set in for the plow and I don't cultivate so they stay that way.
Edited by CTuckerNWIL - 17 Mar 2012 at 9:18pm
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 9:41pm
With the tractor parked you can take the top one off and clean it and free it up, then reinstall it.  Roll the tractor ahead and take the next one out.  Rinse and repeat till you get em all.
Worked well enough for me mine turn like a dream now.
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 9:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 11:13pm
I used to use the ones on my 58 D14 at least once a year - they never seized up.  However, the ones on my 59 D14 and D15 II were never used and consequently stuck.  After separating the rim from the castings, I threw the eccentrics in the woodstove for a few hours.  They all turned freely after that, however I still took them apart and sandblasted everything.  Put it back together with lots of anti seize, it should last a good long time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 8:09am
Booger, I love that picture!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 7:57pm
if you will take them apart,clean them up,and get some FELPOR C5-A ANTI SIEZE you will be able to loosen them normally after 15 years of use...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 8:03pm
Yep Ted. I got a bang out of it too, God Bless !!!
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 8:16pm
Thanks for that!LOL
Galatians 5:22-24
This page was generated in 2.063 seconds.
