My Project 48'B |
juniorp53 ![]() Bronze Level ![]() Joined: 16 Mar 2012 Location: United States Points: 51 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Mar 2012 at 3:16pm |
newbie here sharing pictures of my project of what i believe to be a 48' B it sat like this for ten years after the sale of the farm was in running condition when it left but needed a ring gear
couldn't believe that 3 of the 4 tires still had air in them drained what seemed like 3 gallons of water from inside the engine as the exhaust was left uncovered I guess my question is as ive some people talk about rebuild kits.. are they all the same because the prices seem to differ as much as $200 and as a student i am not looking to spend a ton of money but i also dont want to do this again. Also what muffler is this suppose to have on it ? Can i have the holes in exhaust manifold welded shut? they are not very big? |
stray ![]() Orange Level ![]() ![]() Joined: 16 Aug 2011 Location: Tipton, Missour Points: 323 |
Welcome to the board. On rebuild kits yes there is differances in them, I will let someone else reccomend what one is the best. I'm not very fimaliar with the B's. Your holes on the exaust manifold, can be welded but are you sure you want to. If they are there from the factory why would you want to?
1969 190XT series 3
stray,
Guess i should have clarified the "Rust holes" in the top half of the exhaust manifold. There not to big and id like to save myself from buying a new manifold
dave63 ![]() Orange Level ![]() ![]() Joined: 01 Feb 2011 Location: Lineboro Md Points: 2382 |
Exhaust manifolds get thin and develop small holes in the thin spots, they can be welded if there is something to weld to and you understand cast iron welding. It is likly that it is to thin and it may not work out.
The universal answer to all questions is yes, how much do you want to spend?
GlenninPA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Just buy a used manifold off ePay....
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
If it is rust holes I wouldn't try, I'm not saying that it can't be done, but I feel it wouldn't be worth the time when you can buy a aftermarket for around $100.00.
1969 190XT series 3
If you are paying a welding shop to weld it, you're wasting time and money. If you think you can weld it and your time isn't work much, give it a try. I bought a nice original manifold needing a data plate for $3 at an auction last year. I plan to mill it flat and find a data plate so I can use it on my B.
AJ ![]() Orange Level ![]() Joined: 31 Oct 2010 Location: mo Points: 5244 |
I believe you have an allis c with a wide front. The draw bar in the picture with it on the trailer seems to look like a c. I could be wrong tho. As for the manifold, don't waste your time or money trying to weld up the holes in it. Just get another one. They aren't hard to fine and don't cost that much. I may have one I could sell u. Looks like it has potential. Wish I had it.
Aj. Edited by AJ - 16 Mar 2012 at 8:08pm |
Can't fix stupid
Sure looks like a C to me too. What is the tractor number stamped next to the shifter. Unless it has been assembled from more than one original, I bet it starts with C.
TMiller/NC ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Does the wide front C steering arm point down out of the steering gear like a B or up like a CA? Tim
I have a 49 B and it has adj front axle and same as C rears.They offered two kinds ,one was stanard and one was adj front axle which came with the C type rear wheels
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87712 |
the rear end looks kind of wide, like a C, and the rear wheels look deep dish like a C.... but the steering box in the 4th photo is definitely from a B and the front axle is a B.
Sounds like someone "pieced" this tractor together at one point in time.
Can't fix stupid
I always wondered the same thing myself as i never knew that model C came in a wide front end version. the model number next to the shifter starts with B the next number after that is 8 but i cant remember beyond that. We had a C back on the farm and when parked next to each other the Rear end of the C was noticeable wider so i believe this to be a B with the optional adjustable front end also has the rear lift to which i have the plows for one bottom for one direction and the other bottom for the other direction. not sure of model number not sure how many options where available my guess is this one has a few of em
They could have put rear axle housing on the B to make it wider. If it starts with a B and has a wider housing thats prolly what they did. So it would sound as if your tractor is alot of tractors in one.
Can't fix stupid
