175 vs 200 diesel
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Topic: 175 vs 200 diesel
    Posted: 28 Feb 2012 at 8:57pm
In the other posts there is discussion of when AC switched from the 175 Buda diesel to the ?Perkins? I think engine. Was this in fact a Perkins engine and what else if anything used the 200 engine and can these engines be sourced?
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 9:16pm
Dave, the HD4 used a 200 CI engine. I think some combines , lift trucks used them too. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 9:21pm
Thanks Tracy. I guess the next question is where can I get one.....
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 9:26pm
A-C switched from the 175 to the 2200 (200 cu.in non turbo) in the 615 industrial tractor which was basicly a D-15II. That the only tractor where there was a switch. The 2200 became  the 433 T engine with a turbo in the 6000 tractors, Gleaner F's, 715C TLB, and some forklifts.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 10:33pm
I`ve not owned any of those machines Calvin, But Norm Swinford says in his book that when the I 60 with 175 diesel was discontinued, the I 600 which replaced it, had the 2200 engine and 615s changed at 5001. I took an intrest because I would like to some day own both an HD4 and a D15.     Mac
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 5:46am
I'm travelling and don't have Norm's book to refer to. I am familar with these tractors.
The I-60 and I-600 are the same tractor with the differances being in the backhoe attachment. The 615 gas is also the same tractor but again the backhoe changed.
The I-60 and I-600 both had the 175 diesel the same as the D-15 diesel. The 615 got the 2200 (200 in.) diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 8:59am
So the 200 is not a Prekins engine, it's the 433 engine without a turbo.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 9:09am
Yup, the 200 engine was an AC engine
1968 D15D,1962 D19D
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 5:10pm
 The 200 is 2/3 of a 301.
I started out years ago with nothing.... after this divorce , I'll be getting most of it back.........
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 5:44pm
Which end do ya cut off?Wacko
