Bush Hogging..
smallfarmer83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smallfarmer83 Quote  Post ReplyReply Direct Link To This Post Topic: Bush Hogging..
    Posted: 25 Feb 2012 at 7:15pm
What is the biggest 3Pt bush hog you think a guy could put behind a 200 Allis with front weights, I've been looking at a newer one and would like to get the biggest 3pt possible and best bang for the buck. TIA.
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 12:10am
When I was in High School I worked for a farmer that had I very heavy duty 10ft Bushhog brand 3pt mower and it handled i fine. I'm not sure what the biggest 3pt is but I would think it would handle up to 12ft if they make one and I don't remebering seeing one before.
1969 190XT series 3
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 2:08am
With 93 PTO HP you should be able to run a 15' bat wing mower I would think.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Eddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 7:38am
I run a 10' Howse cutter on a 6060 with a full rack of weights. It handles it great.
Allis Chalmers 6060
10' Howse Rotary Cutter
5' Tiller
5' Box Blade
4' Aerator
Ferris Zero Turn Mower W/10' fold up sprayer
John Deere 455 Lawn Tractor
John Deere 955 w/loader &
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 10:03am
When talking about a 3pt its the weight of the mower that is more problem than hp to turn the mower.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 10:49am
You see the road crews running the large mowers all the time and those tractors sure look smaller than a 200.  Maybe wrong but it seems that way.
1968 one-seventy
1956 F40 Ferguson
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 11:20am
From what I am reading here the concern is more being able to carry the machine weight on the three point arms that running the machine. I had a Bush Hog 3126 full mounted 10 foot cutter, my 190 XT's would handle it fine.   I have never seen a full mounted rotarty cutter wider than 10 feet.  The Woods 121 Twin Cadet appears to be somewhat lighter than the Bush Hog, and I have seen them as full mounts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 12:19pm
Yes, I'm a mechanic for MoDot and we pull 15ft brushhogs all the time with tractors that are smaller than the 200 with no problem at all, But they are pull type not 3pt. like I said it is the weight of the mower that is a problem. I would think that the 200 would handle up to 20' mower that is a pull type.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 12:24pm
I've never seen on either, but I have seen a 12ft solid, not flex wing, mower that could have been mounted 3pt very easy. So I didn't want to say that there wasn't any over 10ft. The 12ft was built just like the 10ft execpt the outside 1 1/2 ft on each side maunally folded up.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote smallfarmer83 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 6:50pm
Thank you to the replies, I'm going this week to pick up 10ft 3point mounted bush hog brand. See how she does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 8:40pm
Oh wow, I must have been asleep at the keyboard again.   Sometimes I can't see the tree because there's a tree in my way.  LOL  I think I'll take the short bus from now on. :>)
1968 one-seventy
1956 F40 Ferguson
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 9:14pm
Best to go is semi mount. Less weight, still have controll of the 3pt.
http://www.usfarmer.com/fetch_file/?id=197251
Uses no top link, think they make them up to 12" double spindle
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
This page was generated in 0.127 seconds.
