385 Planter Questions |
AllisUpstate ![]() Orange Level ![]() Joined: 06 May 2011 Location: Upstate NY Points: 1261 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Feb 2012 at 3:43pm |
I am starting to putter around with the 4 row Deutz-Allis 385 no till planter that I want to use this year. I have never used one of these planters, but have the Agco manual (which is not all that helpful).
I am going to use our D17 IV with it. However, I don't know if the charging system is up to the task. The manual says the 2 blowers require 9 amps a piece, and recommends a minimum of a 32 amp alternator. I just got the generator charging system on the D17 working well, finally. I have kept it as positive ground. Will the blowers work with positive ground? Also, the generator is only 25 amps. However, since I will only be planting 5-10 acres at a time, I was wondering if I could hang an extra battery on the planter, and charge it separately. It seems that might help enough to run the blowers for a while, then I could re-charge it before using it again. Or, will I have to bite the bullet, and switch over to a neg ground alternator? |
Byron WC in SW Wi ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wisconsin Points: 1635 |
I'm not an electrician I doubt very seriously they'd work with a positive ground. Last time I bought a fan motor it was NOS and it was over $100 so I'd be careful whatever you do. I would think a new alternator and proper grounding/voltage/amps would be cheaper than replacing the motors. My 385 has a monitor too so that's going to take some power as well. The 385 is a great planter.
Byron,
Thanks for the feedback. I am starting to come around to the same conclusion, that I need to go to neg ground, and might as well add a decent alternator. I have another really dumb question. The 385 is driven by the ground wheels. However, I don't see any particular spring or anything to produce pressure on the driving wheels of the planter. Are they supposed to get enough traction by just hanging down on their own weight? |
