B/C belly mower |
AJ ![]() Orange Level ![]() Joined: 31 Oct 2010 Location: mo Points: 5244 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Feb 2012 at 11:40am |
Are b and c belly mowers the same? If not, how hard is it to mount a b mower under a c?
Can't fix stupid
BrettPhillips ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
If you mean sickle bar mowers, there is no difference. Rotary mowers are something else entirely. Woods brackets are different between the B and the C/CA to allow for the different distance between final drives.
Dale H. ECIL ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Paris, Il Points: 690 |
Some of the Woods belly rotary mowers have an adjustable pipe on the frame that allows you to put the mower on a B or a C/CA and some do not. I have had both.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
good to know
Can't fix stupid
So the mower don't matter its just the brackets right?
Can't fix stupid
Yes, the only difference is the cross tube push bar that bolts to the final drives. Mine is a 3 piece that will fit B,C, or CA.
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
When the CA came out the number 5 mower was developed. It was basically a B-C mower that was adapted to fit either the B-C or the CA. Only thing needed to make the changes was the kit for the B-C lift arrangement and the kit for the CA lift arrangement. Since the final drives on the CA were angled to the rear it made it a little longer so there was a two position for bolting the mounting brackets on the mower frame.
The B-C sickle bar mower was the same for both. I sure mounted enough of them. In fact, when we sold the B and C for quite some time it was the only mower available. Rotaries were yet to come. Sorry I got a little windy but the question brings back some very good memories. Good Luck! Bill Long |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
I would like to find one of those "multi-fit" mounts to use on my B. if anyone has one.
If you have a B or a C mount, you could do it with a torch or cut-off saw and some new pipe.
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2198 |
I've got all the stuff with a 72" Woods deck that came off of a C... unfortunately, I have two Bs and no C (the mount is non-adjustable). I don't really approve of using these tractors for yard mowing anyway... there's real work to be done with them.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87703 |
mine is a 59 inch on a B.. It had C brackets and i cut and welded to fit the B
