HD6G Track Adjusters
Jay Tyrrell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tyrrell Quote  Post ReplyReply Direct Link To This Post Topic: HD6G Track Adjusters
    Posted: 06 Feb 2012 at 9:14pm
Split the track today to pull off the front idler and get a good look at the yoke. Not good. Gonna drill out the broken piece of track adjuster broke off in the yoke.
Any good ideas how to build a new adjuster?
Was thinking about a 1 1/2" stock, 30" long, put some threads on it and buy a big nut.
Good thing Dads a machinist!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 10:58pm
I have seen that done , using a threaded rod and nut instead of internal threads . Just have to make sure you have enough rod inside the yoke so it doesn't become a bend point to allow yoke to get out of kilter to truck frame .
 I also have seen the yoke re threaded to allow a larger piece to fit inside and hold it in alignment.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 12:59am
Put the yoke in a forge, take heat up to glow point, drop it into waste oil (stand clear of small explosion there), then extract freed broken screw. Machine your new screw to same original thread (which is not a standard engineering one) unless female thread in yoke is completely shot. That is rare. In most cases, male thread only is shot, yoke one is salvageable. I go with a high tensile bar. A buddy told me spiggoting the new threaded bar back a way into the hex bar gives the new scew good strength after welding together. A locking nut of fair depth adds to the rigidity of the screw.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 3:59am
Jay:  See Dozers post for thread size on the HD6 in the previous HD3 Track Adjuster Thread started by hilltop.  I think the 1.600 thread he is referring to applies to the HD 6 tractor, -maybe dozer will see this and clarify.
I am not aware of any 1.600 threads on any HD3 or H3 as these machines had either 1.250" B7 Threaded Rod early and 1.500" later.
HTH's....Orangeman
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 4:58pm
I just finished cutting the thread for my HD6G track adjuster.
1.600 x 5 1/2 TPI Perhaps it is a metric crossover but it fits into my yoke. It is not a 1 5/8 thread. I turned the shaft to 1.590 before I cut the thread. I'm going to weld it onto the old hex adjuster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tyrrell Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 9:26pm
Pretty sure the thread in the yoke is shot. The broken piece is cocked in there.
I'll drill it out and probably do 1 1/2" threaded rod and big nut trick. I'll try to get some pictures posted of what we come up with.
Thanks for the help.
P.S.  Hey Dozer,
Your adjuster looks so short? Any idea how long they should be for a 6G?
Edited by Jay Tyrrell - 07 Feb 2012 at 9:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 12:17am
On the one HD5B I had I had new threads turned onto shaft, then welded that into a square tube with thick walls . It gave me a 4 sided face instead of 6 but is what i had.
I cut the convex end off old adjuster and welded to square tube. Worked great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tyrrell Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 6:45am
Good idea Coke.
I'll rip into it this weekend and see what I come up with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 10:17am
Responding to Jay Tyrrell
The total length of the track adjuster on an HD6G is28.62". What you see in my lathe is the threaded part. I will weld this to the hex part.
The thread that fits in my yoke measures 1.60 x 5 1/2 TPI
If this is supposed to be a metric thread it would be M40x4.6
This is not a normal metric thread either. It is interesting that to be an SAE thread it would be 1.625 diameter. To be a metric 40mm threat it would have to be 1.575 diameter. In each case it is 0.025 off. I'm considering getting some tool steel and making a tap
1 5/8 x 5.5 TPI to clean out the yoke threads.
This page was generated in 0.219 seconds.
