Washing Soda |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Topic: Washing SodaPosted: 01 Feb 2012 at 8:12am |
I have seen mention of washing soda on this site especially for cleaning radiators and engines of gunk. In one thread they mentioned Wallyworld for getting it.
Is 'washing soda' Arm and Hammer laundry soap? I searched Wallyworld
for 'washing soda' and came up empty. Whats the name for it?
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8731 |
Posted: 01 Feb 2012 at 8:19am |
It's a pool treatment chemical.Changes ph. Got one in the shop but can't remember name.
SODIUM CARBONATE
Edited by SteveM C/IL - 01 Feb 2012 at 8:22am |
KenBWisc
Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1185 |
Posted: 01 Feb 2012 at 8:21am |
Many laundry soaps may have washing soda in therm but you're looking for washing soda only. It is different from baking soda. Although I've been watching the selves at Walmart for several months I only found it stocked in December. Bought two boxes. Prior to that I purchased it from a pool service guy. It is cheap! Dish washing power may contain more washing soda than laundry. I'm sure better chemists than I will add to this tread.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 01 Feb 2012 at 8:32am |
I think it is also called "TSP" (TriSodaPhosphate). TSP works great for flushing out my tractors.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Ed-In
Joined: 15 Oct 2009 Location: Frankfort Points: 107 |
Posted: 01 Feb 2012 at 8:40am |
Is this the same as " Iron Out" and can this be used to put in radiator to clean it and the block?
Posted: 01 Feb 2012 at 8:42am |
I don't think phosphate and carbonate are the same thing. Phosphorus VS Carbon
Brian G. NY
Posted: 01 Feb 2012 at 10:29am |
Arm and Hammer Super Washing Soda.
Comes in a 55 oz. box.I bought a box of it (I believe at Wallyworld) last summer to get the "funky" sweat smell out of my work clothes when I wash them.
I used it back in the 60s to flush the cooling system in my Flathaead '50 Ford P.U.
Worked quite well but you would think there might be better alternatives today?
I think "Iron Out" contains Oxalic Acid.
Oxalic Acid Crystals can be bought in a drug store.
Years ago we had a real bad rust build up in our dishwasher and someone told ust to buy the Oxalic Acid crystals and run it thru a cycle; you would not believe how it took the "red" out!
I don't remember how much I used but I had purchased a 1 lb. bottle and I think there is more than 3/4 of it left.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42086 |
Posted: 01 Feb 2012 at 11:13am |
We used SPREX for pre-cleaning metal before coating it with photo-resist for chemical milling process. Used in a hot tank for soak and dip cleaning.
We also used it in electrolysis cleaning before milling process to remove any residue left and any surface oxidation. |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6546 |
Posted: 01 Feb 2012 at 12:30pm |
I have bought the Arm and Hammer super washing soda in Publix and Bi-Lo grocery stores. I use it in my electrolysis tank. Have not tried it for radiator cleaning.
Roger Nolin
Joined: 12 Sep 2009 Location: Monroe Iowa Points: 189 |
Posted: 01 Feb 2012 at 2:13pm |
Fareway stores carry it in central Iowa
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
In the Northeast, it is carried in Wegmans supermarkets.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
Allis B in PA
Posted: 01 Feb 2012 at 2:19pm |
I can find it in most grocery stores here in the northeast as well...I use it to make laundry soap
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2683 |
Posted: 01 Feb 2012 at 4:22pm |
Ted you won't find it around here. Go to the pool department and get sodium carbonate . It's used to increase ph in pools. I have some around somewhere. Same stuff to use for electrolysis rust removal.
wjohn
Posted: 01 Feb 2012 at 6:30pm |
I get it at Rural King... TSC or Farm and Fleet might have it.
Jason in MO
Joined: 21 Feb 2011 Location: SE Missouri Points: 169 |
Posted: 01 Feb 2012 at 7:09pm |
You could take regular baking soda and put it in an over to make your own washing soda. At temperatures above 300°F (149°C), sodium bicarbonate decomposes into sodium carbonate.
Gerald J.
Posted: 01 Feb 2012 at 8:12pm |
According to my Merck chemical index, washing soda is the decahydrate of of sodium carbonate. And sodium bicarbonate is made from sodium carbonate, water, and carbon dioxide. Merck says that sodium bicarbonate looses co2 at 50C and by 100C is sodium carbonate. In a water solution it begins to break up into carbon dioxide and sodium carbonate at 20C and completely on boiling.
The sodium carbonate decahydrate known as washing soda is also known as sal soda, natrite, or natron. Gerald J. |
