? power steering fluid Char-Lynn |
Michael Welch ![]() Bronze Level ![]() Joined: 14 Sep 2009 Location: Jasonville IN Points: 28 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jan 2012 at 8:19pm |
I have a WD45 with Char-Lynn power steering what kind of fluid do I need? Thanks Michael
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
i use dextron in the power steering on my WD45. |
ctbowles58 ![]() Orange Level ![]() ![]() Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
"back in the day" thay used ATF type F
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Automotive ps fluid or Hydraulic fluid will work with the char lynn unit. The pump is the same as used on Ford and Chrysler cars in the 50's. You do not need the additives in the transmission fluid.
I'm having trouble bleeding the air out.
Rich--MN ![]() Orange Level ![]() Joined: 31 Jul 2011 Location: Ramsey,MN Points: 952 |
Do not know if my D 17IV has that brand of steering pump, but when I replaced the bearings and after filling it with fluid, I cranked up the engine and had the air problem.stopped the engine and cracked the output line, recranked the engine and with oil squirting/spurting after a bit it was retighten the line to get rid of the air.
