D-17 226 adding turbo |
kerrdawg40
Topic: D-17 226 adding turboPosted: 17 Jan 2012 at 11:12am |
Was thinking about adding a keystone turbo kit to my D-17 226 GAS . There website stated that I would need a bigger carb . Could someone enlighten me on what size carb I would need to go to and info on where to get it . Engine is stock and with changed govenor spring turns around 2100 -2200 rpms , have turned up to 2800-3000 with a pull on the extra throttle I installed. Tractor used for pulling comp . only .
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 17 Jan 2012 at 11:55am |
at least double the size of what you have now. rule of thumb 15 psi of boost double the horsepower. turbo needs to move at least 300 cfms of air or its a waste of time. Edited by mlpankey - 17 Jan 2012 at 12:13pm |
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 17 Jan 2012 at 12:03pm |
I have a Zenith 12957 off a 262 Gleaner that should feed that. Your stock cast iron fly wheel could grenade at hi rpm, and the power director clutch may not be safe at 3000 rpm, either.
KGood
Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
Posted: 17 Jan 2012 at 12:12pm |
Or a 301 gas carb with a bigger venturi. I'd like to do that to someday with my WC.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 17 Jan 2012 at 3:45pm |
Is is possible to put injectors in and eliminate the carb? I'm sure it's been done.
Wink I am a Russian Bot |
mlpankey
Posted: 17 Jan 2012 at 5:49pm |
yeap its possible
Larry(OH)
Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Posted: 18 Jan 2012 at 5:09am |
I had a bendix(if I remember right) off a G gleaner on my WC witht he hot cam in it. I never had a fuel problem with it. Sold the manifold to someone on here that I had made where there was no overhang on it.
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
MACK
Posted: 18 Jan 2012 at 6:32am |
What is your plans for rods? MACK
Posted: 18 Jan 2012 at 6:56am |
GREAT POINT, MACK !!.......and if a tractor like that showed up at any Pull around here, I doubt it would be allowed to even hook to the sled.......Why, you ask?? well first, what class are you going to put it in ?? and with zero safety equipment, no insurance company would want anything to do with it.
kerrdawg40
Posted: 18 Jan 2012 at 9:33am |
Mack are you saying the rods will not hold up at 2100-2200 rpm with a turbo charger, just asking before I put one on it . Also Dr. Allis there are under 3000 rpm farm classses without a blanket and you can run a turbo . Didnt know that since I had an antique tractor I was limited to antique pulling classes. Just enjoy pulling .
mlpankey
Posted: 18 Jan 2012 at 9:45am |
Rods will be a issue .
kerrdawg40
Posted: 18 Jan 2012 at 10:57am |
Ok thx, for everyones input .
MACK
Posted: 18 Jan 2012 at 9:48pm |
The D17 rods will fold up with turbo boost and when they do it will try to push the crank out the bottom if it don't burn a hole through your cast aluminum pistons first. MACK |
