C carb question
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: C carb question
    Posted: 16 Jan 2012 at 10:09am
Is there a way to find out what model Zenith carb is on a 48 C without taking the carb off?
There is a tag on the carb, but I'd rather not take the carb off just to read the tag. (The tag is at the back, against the block.)
Edited by Goose - 16 Jan 2012 at 10:10am
Texas B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas B Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:20am
Mirror and flash light won't work?
Texas B 39
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:30am
I tried that this morning. The tag is rather black with junk on it. I tried wiping it with a Q tip and some spray cleaner, but unsuccessful so far. I could try again tonight.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:31am
The tag is the only method I know of - but that's not saying much, because I haven't been working on these carbs my whole life. Clean off the tag well and try Texas B's suggestion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas B Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:37am
Get something that eats paint - some of the good carb cleaner out of the bucket or paint remover or brake fluid - then steel wool wrapped around a small dowel.  Gets you clean and a little shine on the high spots.
Texas B 39
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 5:57pm
The B & C model Tractors shared the same carbs in most cases. Here's a few popular Zenith numbers that came on those particular model Tractors.
212845,212845-2,216937,224641,212844,212844-2,  I've rebuilt most of em' and have the rebuild kits in stock for most AC applications.   HTH
Steve@B&B
This page was generated in 0.172 seconds.
