wd 45 wide front
bill(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill(IL) Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 wide front
    Posted: 09 Jan 2012 at 9:14am
I have a 1953 wd 45 narrow front. I bought a 4 bolt wide front that I am going to put on it. The hand crank shaft and bracket are missing. Can anyone tell me if the narrow front parts are the same. I can't get pictures to come up on Agco parts books. Thanks   Bill
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 10:15am
I'm not sure. The wide front & single front wheel use the same pedestal, the standard tricycle front is different, but I think these parts are the same on all of them. They should also work with those same parts off a WC or WD. Kip
HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
bryan/silex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan/silex Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 12:48pm
I would have to look and see, but it seems to me that on the wide front that shaft comes out the front at an angle,  not straight like the narrow front. so i think they are different.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 4:20pm
Like Bryan says. The only difference appears to be the universal at the end of the shaft to allow for the angle.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 4:44pm
Yes the shaft #6, #5, #4, #3, #2 are diff.
Someone on here is making the parts to fix wide/ single wheel front end hand cranks.
Don
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 7:10pm
  yes they are different   byran is right at an angle
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 7:14pm
Are the crank parts on the 4 bolt different from the 3 bolt?
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:04pm
With the shaft and bracket missing, it may be a WD45 Diesel one as they didn't have a crank for them.  My 45 gas has a diesel one on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:12pm
If the crank "shaft" thru the pedestal is missing, you should either put a shaft in there or plug the holes.
One of my WD-45s was missing that shaft and when I went to drive it one spring I could not steer it. I mean it would literally NOT steer!
Mice had filled the area with some kind of cotton wadding and it wound itself into the gears. Took a while to dig all that stuff out with a hooked piece of stiff wire.
If it had been the WD, I could have simply taken the cover off to do the job.
I immediately "corked" the holes.
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:13pm
Lonnie, on the wide front crank extension parts are the same for the 3 bolt & 4 bolt. On the narrow fronts the shaft lenth is different, spring and support bracket.  The engine crank pulley is different also. The wide front pulley is machined out larger to fit the swivel.  For the wide fronts the shaft goes through the front casting at an angle to miss the top bearing on the wide & single front ends.that's why they have the swivel to line up to the crank pulley.. I had some crank swivels made and some other stuff.  I'll have to look & see what I have left. hope this helps.
Have a good one BILL P
hOPE THIS HELPS
hAVE A GOOD ONE bill p
Edited by BILLP-SE-MI - 09 Jan 2012 at 9:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:21pm
Well Bill, that's very interesting!
I never realized that!
Anybody who is interested in swapping frontends and wants everything to work had better get the crankshaft pulley to fit.
I won't write that one down because it was such a surprise to me that I probably will not forget it! LOL
Thanks for posting that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 7:12pm
Thanks for all the info. If I can't find all the parts I will just plug the holes for now.   Thanks       Bill
This page was generated in 0.150 seconds.
