WD, WC engine ?
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Topic: WD, WC engine ?
    Posted: 31 Dec 2011 at 10:01am
I was wondering if someone would tell me is there any difference internally or externally between a WC engine and an early WD (short head) engine?
Pete
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 10:05am
Pete, I think the WC, or at least some of them, had different sized main bearings. Happy New Year to you! Michael
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 10:57am
I believe that change happened in 1935, went from 2" to 2 3/8".
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 4:05pm
Aside from the really early blocks that you most likely will not encounter that had the smaller mains, the earlier WC blocks did not use as many head bolts as later WC/WD/WD45 blocks. Not sure when A-C changed the head bolt count but think it was some time after 1940. You can still put a later head on one of these earlier blocks. Externally all WC/WD blocks look the same. Kip
HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 4:26pm
I would suspect if you tore down a 1948 model WC engine, it would be nearly identical to a 1948 WD engine except for the governor spring. Compression ratios should have been the same by then for gasoline models.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 5:06pm
My dealers parts book showed around 6 different compression ratio option pistons for the WC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 7:48pm
Thanks for the info everyone! That's kind of what I thought.
Happy New Year to you too Michael, and to everyone else on the forum!
Pete
This page was generated in 0.104 seconds.
