more D19d questions |
ACscott
Topic: more D19d questionsPosted: 08 Dec 2011 at 6:10pm |
The engine shop just called me with some more bad news the oil pump was already welded once before and its cracking again, they said i would be better off putting in a new one, my question is where can you get one. is it the same as a gas D19? also they said they need some bolt that goes in the cylinder head to hold the rockers on that is hollow for lubrication, is there such a bolt in this engine ? I cant remember, thanks Edited by ACscott - 08 Dec 2011 at 7:04pm |
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 08 Dec 2011 at 7:56pm |
You're probably just going to have to get a used one. From what I was told when I overhauled my 262, the oil pumps were quite robust. I only replaced mine because the "ears" that the bolts go through were broken off and welded back on. There is also a later design that has a relief valve in the outlet. Aside from that, they should be the same. I should know this for sure, but I don't remember there being a special bolt for the rocker shaft. I'd like to say the one of the stands was larger so the oil flowed around the bolt.
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 08 Dec 2011 at 8:07pm |
Are they similar to D-17D pumps? i have one if it would help. Have 230 buda/WD45D pumps also, brazing on tabs though.
I have the "Stud" that carries oil thru for the 230 buda 6 cyl engine, NOS. Probaly noot the same, I can post part number if you want to check numbers. Edited by Chris/CT - 08 Dec 2011 at 8:10pm |
ACscott
Posted: 08 Dec 2011 at 8:21pm |
Chris that would be great if you could post the part number. Others opinions would still be appreciated about this bolt, maybe there is no such thing in the D19 you guys have a lot more knowledge than me.
D-17_Dave
Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Posted: 08 Dec 2011 at 8:25pm |
There is a bolte that holds the rocker assembly that is hollow that carries the oil to the rocker shaft.
Travis(NE)
Joined: 24 Sep 2009 Location: Seward NE Points: 300 |
Posted: 08 Dec 2011 at 8:44pm |
The bolt for the rockers is actually a stud with a grove cut the whole length as an oil path. There is usually two of them and they serve as the valve cover hold down points.
As for the oil pump the 230/WD45D is different. The gas and later D17's with the relief would be the same.
ACscott
Posted: 08 Dec 2011 at 9:00pm |
Dave or travis on agco parts books are these studs part# 7450861 ? thanks
Travis(NE)
Posted: 08 Dec 2011 at 9:12pm |
I am on my iPad at the moment away from all my other resources and AGCO parts books online doesn't work with iPad. I can look tomorrow for you unless somebody beats me to it.
MACK
Posted: 08 Dec 2011 at 9:31pm |
To keep from breakeing the ears off the oil pump, drill holes in bolt heads and snug them down then wire them.
I'm sure I have some oil pumps, will look in the morning if you want one. Does yours have the relief valve in the line? MACK
nevans
Joined: 06 Dec 2011 Location: Red Bud. IL Points: 837 |
Posted: 08 Dec 2011 at 9:47pm |
If mack doesn't have one we do just let me know 1 618 282 2477 or 282 2048 at night niel
ACscott
Posted: 08 Dec 2011 at 10:44pm |
Does anybody have the 2 studs i need to hold the valve cover on that travis talked about?
Chris/CT
Posted: 09 Dec 2011 at 4:21am |
The D-17 pump I have is later D17 w/ relief, looks like you have plenty of availability there. If those studs w/ groove are same part number, I should have 1 possibly 2 if that helps.
Travis(NE)
Posted: 09 Dec 2011 at 10:47am |
I stand corrected the studs are only grooved part of the length. Correct part#74508061
KenBWisc
Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1186 |
Posted: 09 Dec 2011 at 11:31am |
A groove can be put into rocker arm studs without the groove with a cutoff tool. Just get the right diameter/length and tread and cut them in.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Chris/CT
Posted: 09 Dec 2011 at 4:09pm |
I have one NOS #74508061 stud, probably find another used one. Advise sounds good on the "groove" milled on site to regular standard stud, assuming length is the same? Will need to clean-up threads if done with a cut-off tool.
MACK
Posted: 09 Dec 2011 at 6:00pm |
I have both oil pumps. Let me know. 660 828 4310 MACK
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3661 |
Posted: 09 Dec 2011 at 6:10pm |
when you get a pump - remember - and this is important - on at least some of these units if not all the 'ears' do NOT touch the block - Better check I think they torque to something like 20 foot lbs. I have seen many pumps with brazed 'ears' before finding this out. .
TomMN
Joined: 13 Sep 2009 Location: Elbow Lake, MN Points: 858 |
Posted: 09 Dec 2011 at 6:34pm |
This is that bolt on a WD45 Diesel using the starter to spin it over to get some oil pumped through lines.
ACscott
Posted: 09 Dec 2011 at 10:58pm |
Thanks everyone for their input and thanks to tom and travis for the pictures, mack if i cant find a pump in canada i will let you know.
