Chrome exhaust pipe
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Chrome exhaust pipe
    Posted: 07 Dec 2011 at 10:08pm
I am looking at getting a chrome exhaust pipe for my 190XT.  I've seen several that get discolored at the bottom closer to the turbo elbow.  What is the best kind to get so that this does not happen?
Any advice would be appreciated!
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 10:16pm
I don't know if they make them for tractors, but double wall chrome pipes are used on motorcycles to prevent discoloring.
SenseiCrusher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SenseiCrusher Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 1:26am
Run a perforated feeder pipe inside the chrome one.
Edited by SenseiCrusher - 08 Dec 2011 at 1:28am
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 3:46am
Purple is good!!!
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 6:21am
I run a 4" pipe inside the 5" chrome pipe on my D-21. No discolouring after cultivating 1000 acres. I have a real good system with no welding and everything below the hood for putting this together. I worked with my local heavy truck parts supplier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 6:24am
They actually do make the double-wall chrome ones for tractors. I looked at them for some of my tractors. I've got to leave for school and don't have time to look right now but if you guys haven't found them by this afternoon I will be glad to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 6:27am
Edited by Calvin Schmidt - 08 Dec 2011 at 6:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 6:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 6:36am
I used a 3" to 4" adaptor off the turbo and installed a 4" pipe up to the curve of the chrome pipe. I then slid a 4" to 5" adaptor down the 4" pipe with the big end down. Next the 5" chrome fits on to the second adaptor.  You will likely want to go 3" to 4" on a one ninety so you can eliminate the first step. Both tractors above have this setup but only the one with the curved pipe is mine.
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 6:18am
the best one is from Thomure in East Prairie Mo,800-527-9954 ask for Dave,these have the best looking bend if u want the curve,so many have such a ugly curve,if u don't have one from this place u don't have the "good one"
