no steering pump humming |
giz's hd-6ep
Joined: 22 Aug 2010 Location: silver creek ny Points: 35 |
Topic: no steering pump hummingPosted: 04 Dec 2011 at 5:26pm |
hello everyone i had the hd6- ep out for a spin today and all was well so i started pushing brush around and all of a sudden no steering . moves back and forth alright and noticed pressure gauges are both low and fluctuating .also the cessena pump mounted on torque convertor housing is humming and vibrating so i figured either the pump is going or screen is plugged in pickup what do you guys think .
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42280 |
Posted: 04 Dec 2011 at 6:33pm |
sounds like cavitation of pump , some exploring and finding if input is restricted.
giz's hd-6ep
Posted: 04 Dec 2011 at 6:57pm |
yea gonna check screen it's on bottom near where large suction hose goes in tranny right ? is there a cover i can take off ? and i've been using tractor hyd fluid should i be using atf??
doctorcorey
Joined: 17 Jul 2011 Location: S. KC Missouri Points: 589 |
Posted: 05 Dec 2011 at 9:26am |
I've been using tractor hyd. fluid also. I think it contributes to the problem. I'm switching to the 10w oil (champion brand) as recommended by AC. It's about the same price as ATF and very thin. I've got the same problem as you and I'm sure it's the screen, but a SOB to get to!
doctorcorey
Posted: 05 Dec 2011 at 9:28am |
