180 diesel starter problems |
ScottinSWIL
Joined: 30 Oct 2009 Location: Randolph Co. IL Points: 118 |
Topic: 180 diesel starter problemsPosted: 21 Nov 2011 at 3:28pm |
Have been fighting a starting problem on an 180 for some time now . Awhile back we replaced the old worn out Delco starter with one of the new style gear reduction starters form A & I, with is great for the size, weight and ease of installation. The problem is on various occasions all I will have is a "click-click" at the starter even with a full 12.5 plus volts reading there all the time. I have replaced the safety switch on the clutch as well as the wires leading to and from the switch. I guess it is very possible the new starter has a weak solenoid. The only sure way to get the thing going sometimes is to put the battery booster on the engine heater relay located under the right hand side below the fuel tank. This has become very aggravating as it will work 9 out of 10 times but then you might be dead in the water. Batteries and cables are all new. Would'nt a faulty solenoid work if you crossed the terminals with a screwdriver, with full voltage? This has me puzzled because I used it to auger grain this fall and usually fired right up. The other day went to move it around in the shed and could not get the starter to hit a lick. Today, without doing a thing different (other than choice words) it fires off on the first push of the button. Thoughts or suggestions appreciated as I"m ready to take the starter off and have tested, which naturally will not act up at the test stand. Thanks
bdallman
Joined: 14 Nov 2011 Location: Holton KS Points: 1133 |
Posted: 21 Nov 2011 at 4:06pm |
I guess my questions is Whats your Cold Cranking Amps for your new Battery? And yes the starter should turn right over if you by-pass the solonoid with a scredriver. I am just thinking maybe the battery is not a strong enough battery to engage anything when its cold out. I doubt it but just throwing out ideas.
Good Luck
1954 CA, 1952 WD with Freeman Loader,1955 WD45, 1963 D19 Gas, 1984 620H, 1980’s AC Forklift, 66 All Crop Harvester, White Top Roto Baler, Misc S.C. Equip and AC Collectibles.
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 21 Nov 2011 at 4:19pm |
You know our D-21 will do this every once in a while, and it has the factory starter. It will go click, click clunck, then start, if you release then press the starter button. The only thing we keep kicking around is either a worn spont on the ring gear, keeping the bendix from being able to engage the ring, or some dirt in the solenoid. Once you bump it a few times it kicks in and does it's job. It doesn't do it all the time, but every once in a while, it will catch you off guard.
Still in use:
DougS
Posted: 21 Nov 2011 at 5:15pm |
If your replacement starter is still under warranty, consider sending it back. If the starter goes click, the problem will not be an interlock. If you have 12 volts at the starter when cranking it, the problem will not be at a connection. This leaves you with the starter or solenoid as the usual suspects.
Edited by DougS - 21 Nov 2011 at 5:17pm |
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 21 Nov 2011 at 5:36pm |
My guess would be a corroded connection between the starter and the battery. Happens on my 190 quite often.
ScottinSWIL
Posted: 21 Nov 2011 at 6:42pm |
Could it be possible that where the cables meet on the right hand side where they hook together for the manifold heating element could be a drop in voltage or ? As I said you can put the booster to the battery with usually no success there but if you attach it to the heating relay(not sure if that is the correct description) it will generally kick the starter in. This has been going on in a limited way for almost 2 yrs now, so the starter is out of warranty. One of those things where we replaced the safety switch and some wiring and thought we had it licked but lately the same problem is rearing its ugly head again. Had a starter on TL100 New Holland tractor a couple of years ago acting up very similar with the solenoid being the suspect. Took it to a very reputable starter and alternator shop only to be told it was fine, only later we ended up buying a rebuilt starter from CNH and it has never missed a beat since, so I'm leaning towards the fact that the new starter was never up to snuff. Those new stlye starters are great as far as installing with the light weight and smaller size makes it fit without removing any fuel lines or whatever. Sounds like a old Dodge turning over,
DougS
Posted: 21 Nov 2011 at 8:00pm |
Put your voltmeter right on the starter stud. It will read 12.6 volts or so. Have someone attempt to crank the engine while you are holding the meter on the starter stud. If the voltage stays above 10 volts or so and the starter only goes click, the problem will NOT be a connection.
hillmonkey
Joined: 03 Apr 2010 Location: oville fl Points: 417 |
Posted: 21 Nov 2011 at 9:26pm |
bad ground, clean the ground at the batt. clean and install lock washers on each side of the frame eye ground (sandwich style).hm
MACK
Posted: 21 Nov 2011 at 9:45pm |
Put another solenold ahead of the starter. Use #10 wire from battery cable up to solenold and back down to where white wire was hooked on starter. It is not getting enough voltage at the white wire on solenold after going through cheep made safty switch and wire commections. MACK
stray
Joined: 16 Aug 2011 Location: Tipton, Missour Points: 323 |
Posted: 22 Nov 2011 at 8:52pm |
The only way to really tell where the problem is, is to do what is called a voltage drop test on each componet while your trying to start the tractor but it is acting up. To do a voltage drop you take a voltmeter and check each side of a componet the only place there should be a major voltage drop is at the starter motor. Example is place one lead on the positve battery clamp and the other where the positve cable hooks to the starter soleniod try to start the tractor and read the meter if there is a voltage drop (3 or more volts) then your problem is the postive battery cable or the conection at the starter soleniod. If this don't make sense let me know and I will try to draw up a diagram to show you what I'm talking about.
1969 190XT series 3
Orange Blood
Posted: 22 Nov 2011 at 8:58pm |
Actually Stray, I am sorry to disagree, if you place the meter lead on the positive and then probe the rest of the circuit on parts that should be positive, you should read 0 volts or there about, if you find a problem voltage will actually go up from zero. Your suggestion would work great if you placed the lead on the negative terminal, and then probed the positive system.
Still in use:
stray
Posted: 22 Nov 2011 at 9:58pm |
You are right if the cable is good it will read some where around 0 volts. On a voltage drop test the problem will be between the to test leads in an area that shows voltage, unless you are checking across the load (in this example the starter motor). It is called a voltage drop test, you are checking for were you are loosing voltage. If you attach the lead to the negative post and on the postive side of the starter all you know is that the starter circuit used 12 volts like it should. I deal with delicate computer circuits in heavy trucks every day you can't use a test light for load because you don't know what the draw is, and just checking voltage (like you are suggesting) don't put a load on the circuit and then all you need is 1 little strand of wire to conduct electricty and you will show the proper voltage. If you will systematicly eleminate each componet of the circuit you can find the problem with out guessing. After I assured that I was getting voltage to the starter soleniod I would check for voltage drop accross the positve cable like I discribe above then I would check the ground side negative post to starter housing. If both of them are very near 0 volts then I would check across both large termianls on the soleniod there you should also have near 0 volts. then form the large bottom post on the soleniod and the starter housing and you should have near battery voltage (12 volts). It is possible (but not common) to have a open circuit inside the starter and you will show voltage in the right places, but there won't be a voltage drop across the starter. One other thing keep in mind that you must be using the circuit to make this test work, in this case you have to be trying to start the tractor while you are reading the meter.
1969 190XT series 3
Orange Blood
Posted: 22 Nov 2011 at 10:14pm |
Well since you stated your experiance, I am an also a degreed electronics technician, and a former electrician. I will agree with your second explanation. I am not talking potential either, I was reffereing to you test when load applied, i.e. starter button pressed. I never said anything about a test light, I said meter. You said in your previous post that if you attach one lead of a meter to the positive battery terminal, and then use the other lead on the solenoid, and try to start the tractor, and if there is a voltage drop (3 or more volts) I suggest that you are incorrect, IF any portion of that cable or connection is bad, while the button is pushed you will read 12ish volts my friend, because you will read voltage across the open. There will be no "drop", it will read near full battery voltage. Voltage drop refferes to drop from source, in this case 12 volts. When you say around 3 volts or more, it means you would see 9ish volts, that would not be correct if the problem were in the positive cable. Now it could be if the starter was trying to turn the engine, the fault may not be a completely through the cable or connection. Edited by Orange Blood - 22 Nov 2011 at 10:18pm |
Still in use:
Orange Blood
Posted: 22 Nov 2011 at 10:26pm |
All of this is assuming the solenoid is able to pull in, making the high current connection, and completing the starter circuit. Otherwise neither one of us is right.
Still in use:
stray
Posted: 22 Nov 2011 at 10:33pm |
Most of the time you are right the voltage drop will be completely, more so in tractors and farm equipment. But I've had several bad cables that showed a voltage drop of 7 to 9 volts. And even more cable clamps to battery post with even less (4-6 volts). But most of my experance is working on equipment that is used to remove snow and ice and a pin hole in the insulation of the wire and soon salt and cloride starts working and slowly turns copper into green dust. I had one truck a few years ago that the postive clamp to post was loosing 4 volts and the ground clamp to post was loosing 5 volts and just looking at the battery camps they looked good, took them off cleaned them and installed with a little battery termainal protectant and it was good to go.
1969 190XT series 3
stray
Posted: 22 Nov 2011 at 10:38pm |
Yes if the soleniod don't have enough voltage to work, you will have to check the soleniod control circuit.
1969 190XT series 3
Orange Blood
Posted: 22 Nov 2011 at 10:40pm |
Ok, I think we talking about the same thing, but coming at it from different perspectives. The more I think about it, we are both right. I think of drop meaning drop from 12 volts or source, you are not worried about source voltage, you are offering up what the meter would read period.
For me if you say I have a 3 volt drop, and my batt voltage is 12volts, I am thinking the meter is saying 9volts. What I think you are saying is your 3 volt drop means the meter says 3 volts.
Bottom line, in this example, with the meter refference on the positive battery terminal, as the fault gets worse, the number on the mete face rises, until full battery voltage would be read for a full open when a load is placed on the circuit. Right? Edited by Orange Blood - 22 Nov 2011 at 10:43pm |
Still in use:
stray
Posted: 22 Nov 2011 at 10:43pm |
yes exactly.
1969 190XT series 3
Orange Blood
Posted: 22 Nov 2011 at 10:46pm |
What a good example of a discussion forum, not a bashing forum. Thanks for the good discussion, I wasn't trying to step on your toes |
Still in use:
stray
Posted: 22 Nov 2011 at 10:57pm |
Didn't take it that way at all, you were just showing that I need to explain myself better.
1969 190XT series 3
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 23 Nov 2011 at 3:15am |
i had that on my 180D for years, finally it melted the lead apart inside the starter on the starter post, then there was nuthin!!
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34283 |
Posted: 23 Nov 2011 at 5:55am |
Don't take this wrong but it may not be the starter, the truth on engine starting systems is many starters are changed when they are not bad. Get it in the predicament of clicking (hopefully in the shop), pull the starter and check the flywheel ring gear teeth at that place. Six cylinder engines stop +/- four or five teeth at that same three spots on the flywheel, 4 cyl at two, v-8 at 4. The teeth get worn over or flat faced and the bendix will not rotate enough to enter the gear until you bump it a few times as in click click crank.
Sharpening out the teeth to accept the bendix or replacing the gear is all you can do to 'fix' the issue and it will still at times go click click on a sharpened teeth old gear. |
MACK
Posted: 23 Nov 2011 at 7:56am |
If the battery cable was bad it most likely would never start but after some cliks I think it starts. Easy way to ckeck battery cables is with a battery load tester. Start at battery and go down the line.
The place you need to be checking voltage for his problem is the white wire that engauges the solenold. Low voltage here will not pull solenold hard enough to engauge battery cable post to starter post. MACK
