hd19h
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Topic: hd19h
    Posted: 17 Nov 2011 at 2:35pm
I know a guy who has a hd19h its been sitting for 20  years he  said it was running when  his dad parked  it where it is now . the 6 71 detroit fired up the other day  but someone shot holes in the radiator with a .22 and they did not try to move it.  what would a machine like this be worth for sale it had a cable blade and underracarrage looks real good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 2:36pm
sorry it has a cable blade on it
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 10:04pm
sorry cant say anything as to value but i would love to own it
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 6:21pm
are they selling it to get scrap iron value, or are they negotiable so that it gets a good home? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 8:58am
well they sold it for 5k so thats was  probably scrap value  . they told me the guy who bought it had another one that was a push cat and he was going use that for parts or fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 4:24pm
Hope he fixes it up, Darrel
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 5:00am
For the record on HD 19's
A neighbour has one that has been prodified, originally as a farming tractor.
Now 8-71, Spicer heavy duty off road 6 speed box, air cab (very professionally done) and the correct Allis paint which he is using to pull a blade plow.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 1:15am
Be interested to know how the bevel gear pinion ends up where its supposed to
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 2:16am
Mactractor,
If that's on my post on the prodified one -
It still uses the original Allis rear box.  If I remember correctly that is where reverse happens, the Spicer box doesn't have one.  Neighbour had to do a bit of work on the shaft between and found that there had been a bearing change in the front of the original rear box to allow some movement - no splines in the shaft.
As my neighbour says whoever did it knew exactly what they were doing, including finding that the Spicer box would just fit between the rails.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 2:56am
The truck joey boxes had no reverse as there was always one or more in the main box. I believe some joey boxes bolted directly to the main - no drive shaft between
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 3:02am
Mactractor
So our telescopes are pointing the same direction I've just cross checked with the owner.
This HD 19 originally had a 6/71, a diesel converter, a drive shaft  and an Allis 2-speed + reverse box.
It now has an 8/71, a Spicer box (6 + R) a drive shaft and the original Allis 2 + R box.
So he has plenty of ratios to play with.  He hasn't tried Spicer reverse plus Allis reverse to see if it goes forward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 3:49am
Very clever bit of downunder engineering to get favorable ratios for drawbar work Ian.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 4:16am
For the spares side - my neighbour reckons that a lot of things are HD 21 though you might have to change both sides to match the spline.
