WD pulling 5-16 plow!
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Topic: WD pulling 5-16 plow!
    Posted: 12 Nov 2011 at 9:10pm
Yessir,, Pulled it right off the trailer and over to the barnyard, LOL. In fairness I must tell you it isnt a stock WD, has a 4 1/8 M&W kit.
The 9000 plow looking a bit better off the trailer and reassembled tail end. Hope to be able to share some vids of this one working in the spring behind the 220. Will put the two add-ons back on it for that.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 11:05pm
It might pull it in the field if you weigh down the WD and plow 2 or 3 inches deep.
Edited by DougS - 12 Nov 2011 at 11:05pm
D-allis Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 5:26am
very nice plow and tractor
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 6:42am
Butch, Are you going to pull 7 furrows with the 220? Is the plow an on land hitch? How are you going to ballast the 220? I plan to pull a 7 furrow 2500 on land hitch semi mount plow with my 220. I have Mexician hat duals and was planning on using 1500 lb Tyler inside wheel weights. There will also be extra things happening under the hood.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 7:34am
Semi-mount would give you a lot more traction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 10:53am
Calvin, The hitch will go either way currently set for on land. The 220 will have fluid and duals plus a large rack up front. Our ground plows relativly easy, 7 on the 220 should not tax it. Our 220 has some extras under the hood too. Bob, semi mounted isnt an option for us, no hitch
ScooterBuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScooterBuck Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 12:05pm
Hey Butch maybe you should sell me that wd since you don't have any room in the barn:)
How much does a plow like that sell for if you don't mind me asking. I have a 190 XT series III with nothing to hook to it except for a woods blade. Do you own a chisel plow? What do you pull with the D19?
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 2:56pm
You have to hook the "A" to it and see what happens!!!
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 3:46pm
Butch, if it dont workout you can park that plow out in my field. Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 4:37pm
LOL The WD has a spot, the plow will just have to sit out until there is space.  You would be a lot better off findng a semi-mounted if you have a hitch. They go to scrap here, I paid about 1 1/2 x scrap for this one. We do pull a 12 shank chisel with the 220. For the D-19 we have a 4-16 snap coupler semi mounted. All tillage here is strickly recreational.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 11:27pm
Butch - I guess you didn't wait around long at all before going and getting that thing home!  Good deal!  I want to see picture with #6 & #7 bolted back on...hopefully you are not going to make me wait until spring to see it!!!! ;-)
Oh - how good of shape are the bottoms & coulters?  I know you can't tell at all from a Craigslist picture.  Mike
Edited by Skyhighballoon(MO) - 13 Nov 2011 at 11:28pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
This page was generated in 0.175 seconds.
