WD Head?
Obie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Obie Quote  Post ReplyReply Direct Link To This Post Topic: WD Head?
    Posted: 09 Nov 2011 at 10:22am
I am redoing my WD ,so went and found a head to rebuild,got it sent it out for complete rebuild, then reliesed that my WD has a 3 in. head but the rebuilt one is a 4 in.Will this work or must I find a 3 in. I do have several pushrods and a rocker arm from a WD45 parts tractor in the shop.If need to replace doe`s anyone have rebuilt 3in. to trade? THANKS Obie
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 10:30am
As long as you have the matching valve cover and water manifold for the tall head it will bolt right up. Same push rods and valve train in either head. Kip
HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 11:07am
Kip,
I don't understand how the pushrods are the same, the head is an 1" taller??
Still in use:
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 11:22am
Stands are different but since you bought a whole head....I imagine it has everything you need...so all you gotta do is bolt it to your engine.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 12:10pm
The push rods are the same...the difference is in the rocker arm stand height (shorter stand for the taller head). The head will bolt right on and you will need the shorter valve cover.  Rick
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 1:01pm
Did you get different headbolts with it too?
